Battery tender
Old Nov 19, 2006 | 07:30 PM
mhdi22's Avatar
mhdi22
Originally Posted by JC in XTC5
I use the clips on the battery terminal as well - quick and easy.
I also put a timer on the lead so battery only charges a couple of hours per day; and has worked well for past two years.
Old Nov 19, 2006 | 07:39 PM
photoguy's Avatar
photoguy
Originally Posted by peter pan
Where do I get one of those battery tenders
Autozone 34.95
Old Nov 19, 2006 | 07:40 PM
OUR97's Avatar
OUR97
Originally Posted by JDs00PewterCoupe
I have the Battery Tender Plus hooked up to my car and just use the big clips to hook up to the battery. I leave the hood unlatched with the wires running over the fender and then just put my car cover back on the car.
Old Nov 20, 2006 | 05:34 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
This is exactly what I do as well, works great!
Old Nov 20, 2006 | 09:07 AM
b98's Avatar
b98
Always buy a good one. Cheep ones can cause a fire.
Old Nov 20, 2006 | 09:25 AM
426 Hemi's Avatar
426 Hemi
Probably not but is the cigarette lighter on the same circuit as the underhood light, i.e. turns itself off after a period of time?
Old Nov 20, 2006 | 09:51 AM
charlene's Avatar
charlene
St. Jude Donor '04-'05-'06-'07-'08-'09-'10-'11-'12-'13
I have the battery tender plus and i just hook it up i have never put the cables down through the inside of the car when i cover the car i leave the part where the plug from the tender hooks up to the extension cord open so the cable cords are exposed the tender i have seating on a stepstool about two feet from the car.I dont think the lighter charging will charge for along time they are only ment for when you change your battery it is for short term use.......
Old Nov 20, 2006 | 07:14 PM
Rogue Leader's Avatar
Rogue Leader
St. Jude Donor '08
Ok so since my car is going to live under a cover in my driveway for the winter (Dec-Mar), I was thinking to leave this thing on my passenger floor, run the permanent wiring thru the firewall for it, and run the power cable out the bottom of the passenger door and down my driveway to an outdoor outlet. I dont want it outside exposed to the elements, and under the car will do no good as when the snow melts it will get destroyed. Does anyone see a problem with that?
Old Nov 20, 2006 | 07:41 PM
wayne_69_427's Avatar
wayne_69_427
I have them hard wired on both the vettes. I have the red top batterys in both cars so I used the top terminals for the battery tender. On the 2000 I have the wire coming out the fender vent. I just disconnect the batery tender put the cap on the connector and tuck the wire in the vent and I am ready to go.
Old Nov 20, 2006 | 08:19 PM
hotwheels57's Avatar
hotwheels57
The BATTERY TENDER PLUS (or BATTERY TENDER JR.) do create a little heat...I'd be concerned about damaging the carpet/mats if it were my car...but it's your car.
Personally, I like to leave the device outside the car so I can easily see the LED (red or green) and know that it's functioning correctly. My car sits inside a heated shop though. Since your car has to sit outside, at least use something under the device which will insulate the carpet/mat from heat. You might have to worry about critters chewing on the electrical cord or someone tripping over it. If the cord has to be run a long distance, be sure you use a heavy gauge extension cord to get full current.
Old Nov 20, 2006 | 09:11 PM
LarryW's Avatar
LarryW
Well, I've had my Battery Tender Plus hooked up for days/weeks at a time (via the cigarette lighter plug); after the initial recharge/condition, the green LED remains on, solid (with no other LEDs on); so it would appear to me that everything is working correctly
Guess I need to go out to the garage and take a look at it
Larry
Old Nov 20, 2006 | 09:20 PM
TomBoy's Avatar
TomBoy
Never have seen a Battery Tender brand with a cigarette plug. Guess this is a new convenience. I had my husband install the permanent hook up on the battery. Not the alligator clips. This way it is easy for me to hook up all the time. It has a nice top to close it off when not in use. I also bought a cord extender offered online to make the whole thing longer making it easy to park where I want and not have to be next to the plug.
Laurie
Old Nov 20, 2006 | 10:13 PM
  #33
Rogue Leader
St. Jude Donor '08
Yeah I figured on that, So my thought was to remove my nice lloyds mats and just stuff the stocker there then put something underneath.... non flamable. I'm really not sure I mean how hot do they get? I dont want something to melt, and I also dont want to come home to a car fire one day....
Anyone else in my predicament? Maybe I can get the JR and leave it under the hood, theres less to catch fire and probably more than enough room in the battery tray...
Old Nov 20, 2006 | 10:52 PM
  #34
rrichar2591's Avatar
rrichar2591
I use the one from Sears and it will get a little warm but I would not call it hot. Set it on a brick or piece of wood and then keep an eye on it for a few hours. After that, you'll sleep easier. Good luck
Old Nov 20, 2006 | 11:52 PM
  #35
Rogue Leader
St. Jude Donor '08
Hmm not a bad idea... bricks definitely do not burn hehehe
Old Nov 21, 2006 | 05:37 AM
  #36
WvCorvette's Avatar
WvCorvette
I used the Battery Tender with a cigarette adapter all last year with no problems.
Old Nov 21, 2006 | 07:10 AM
  #37
The Punisher's Avatar
The Punisher
To Battery tender
Old Nov 21, 2006 | 07:26 AM
  #38
zozmanZ06's Avatar
zozmanZ06
Default Battery Tender
I bought two of the Battery Tender four-banks. Installed them one each on the opposite sides of the garage walls. The heat sinks vent upwards keeping the units cool. I use the BT's 25-ft. extentions threaded up onto the ceiling which will reach anywhere I need to go in the garage. Cars are connected via clamps to BT running the cord down from the engine compartment and along the wall. Connected, I have two cars, two motorcycles, four scooters. Battery Tender brand have outstanding performance. Buy a four-bank--the extra connections will quickly fill up. Tractor battery here, boat battery there. You get the idea. Tis better to have and not need than to need and not have.
Randy
Old Nov 21, 2006 | 10:39 AM
  #39
hotwheels57
The BATTERY TENDER JR. is waterproof, but only produces .75amp of power. That's fine for long term on a strong battery. It's also small enough to rest somewhere in your engine compartment during the winter...just don't forget it when you start the car...sounds worse than a cat.
Old Nov 21, 2006 | 06:54 PM
  #40
Rogue Leader
St. Jude Donor '08
Id assume my battery is good, however recently The car sat for a week, then I drove it a block and left my hazards on for about an hour (went to a fire call) and it was dead (As in not enough to start but accessories still came on) when I got back. Its a fairly new battery AFAIK... i think it was just cause of the lights and having sat for a week.... I hope
