Climate Control Module
Old Nov 20, 2006 | 08:55 PM
Not Fair's Avatar
Not Fair
Default Climate Control Module
Has anyone had problems with their climate control module? And if you did,what did you do to fix problem? Thanks for your help
Old Nov 20, 2006 | 09:59 PM
Watchful's Avatar
Watchful
From: An Englishman drinking his way through Tewksbury MA
St. Jude Donor '09
Most common problem is fading display. It seems easy enough to repair. Mine was a 30mins solder job, just search the forums for details on what needs soldering.
Old Nov 21, 2006 | 03:56 PM
Not Fair's Avatar
Not Fair
Yes it is the display. I have read that some of the displays just go dim, but the one in my 01 vette has completely gone out. The chevrolet dealership wants about $300 for a new one. That sounds too expensive, but what do I know.
Old Nov 21, 2006 | 05:59 PM
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
Welcome to the wonderful world of Corvette ownership. Do a search and find the one that shows you which points to resolder.
Check out #24 it may help. Good Luck.
http://forums.corvetteforum.com/show...limate+control
The Monk!
Old Nov 21, 2006 | 06:45 PM
40Below's Avatar
40Below
Cruising
Default E-bay
There is a guy at e-bay that will fix it for under $50. I read about him here in Corvette forum. Great service and a very quick turn around.
I opened mine up and decided it was worth the money to have someone else fix it. My screen was dead, but a/c, heat all worked.
Old Nov 24, 2006 | 10:34 PM
Not Fair's Avatar
Not Fair
Thanks for all the help. The pictures are great.
Not Fair
Old Nov 25, 2006 | 01:13 AM
kevin40zx's Avatar
kevin40zx
My display doesn't work at all.
I just remember (push mode three times to get to high and low).
I need a sauder'er'er to fix it.
To Climate Control Module
