TPS repair
Old Nov 20, 2006 | 09:10 PM
garypz53's Avatar
garypz53
Default TPS repair
I have a tire pressure sensor warning popping up. Is this a replace part or battery change in the sensor or what does it take to correct it?
Old Nov 20, 2006 | 09:22 PM
hardtop's Avatar
hardtop
You have to by a sensor, remove wheel, remove tire, remove old sensor, replace new sensor, mount tire, balance wheel/tire, reinstall wheel, relearn tire sensors, drive away.
Maybe you just need to do a relearn first, just to make sure the sensor is trully dead.
Old Nov 20, 2006 | 11:16 PM
There used to be a forum member that took the old sensors and could replace the batteries in them. Haven't heard of anyone getting that done in a while, so not sure if he still does the work or not.
If the sensor is dead, might be best to just buy a new one. Something to consider also is that if one is going dead, are the others far behind?
Old Nov 21, 2006 | 12:27 PM
Choreo's Avatar
Choreo
I have had my car for over 6 years and still have not had a TPS problem yet. However, I am getting ready to put new tires on again and I am thinking it might be a good idea to get new sensors installed at the same time?
I found one vendor that sells these for about $59 each on Ebay since I did not see any on a supporting vendor's site yet. The vendor claims they are new and ordered from GM at the time I place my order. I sent them an email asking how I would know if these had not been already sitting in a parts bin somewhere for 6 years and the batteries already partially run down (especially since I understand that these send an intermittant signal even when the car is stopped). The vendor just responded and said that some last 3 years and some others 5 years, but that 10 years was a myth? Do these sensors not have a production date to check battery freshness? They apparently come with on warranty or guarantee?
Old Nov 21, 2006 | 12:33 PM
Mongolink's Avatar
Mongolink
Default Supporting vendor is....
Fred Bean's... check with Gene at Fred beans and get a price, he does us on the forum well and will take good care of you !!!!
Old Nov 21, 2006 | 12:39 PM
devnull's Avatar
devnull
Scientific Negotiator
St. Jude Donor '07-'08-'10, '14
Gene is not there anymore... ---> http://forums.corvetteforum.com/show....php?t=1554518
Old Nov 21, 2006 | 12:58 PM
Mongolink's Avatar
Mongolink
Default well that sucks !!!
But thanks for the heads up... Now those mods will halfta wait till Gene is up and running again !!!
No matter where he lands, he will do well !!!!
Old Nov 21, 2006 | 11:56 PM
Choreo's Avatar
Choreo
Looks like Eckler's carries these at the same price I found on Ebay. Still don't know how to determine how recently they were manufactured?
Old Nov 22, 2006 | 06:42 AM
corvettezman's Avatar
corvettezman
St. Jude Donor '11-'12-'13, '15, '16-'17-'18-'19
make sure you get the right sensor for your car . and i agree , if you have a dead sensor , I would replace all 4 because the others will soon follow .
make sure of the right part number for your year . the 97-00 are larger and quite a bit more expensive . the 01-04 are less than 50 bucks each .
Old Nov 22, 2006 | 09:24 AM
btchn99's Avatar
btchn99
From: "Never play games with a bitch who can play them better" NE PA
Cruise-In VIII & IX Veteran
Posted a WTB for sensors for my 99 and not much luck. I am sending my car to the "doctor" over the winter to get her preped for Carlisle and new wheels and tires are on the list. My husband also wants new sensors---can you tell me what the link was so my husband can check them out (he hasn't been able to find any either). Having a hard time finding them at a reasonable price. I will need to get them soon to send to Tom Z Wheels so he can install them with my wheels and tires. If you wouldn't mind PMing me this info..
Lori
Old Nov 24, 2006 | 09:31 AM
hardtop's Avatar
hardtop
Yes, the sensor is clearly stamped with the date of manufacture.
Old Nov 24, 2006 | 01:08 PM
Bill Dearborn's Avatar
Bill Dearborn
The 97-00 sensors do not broadcast unless spinning on a wheel or activated with a magnet.
Bill
Old Nov 24, 2006 | 02:54 PM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
I would be able to replace betteries for you after Thanksgiving ...
I got the pro doing all the solder so you will get best result.
-Mike
To TPS repair
