Help with Door Bezel
Old Nov 21, 2006 | 03:00 PM
ALLEGRO's Avatar
ALLEGRO
Default Help with Door Bezel
How do you remove (and tighten) the surround for the inside door handle. Mine looks like it is coming off and is loose.
Thanks in advance.
Old Nov 21, 2006 | 03:05 PM
HummelS's Avatar
HummelS
I think it just snaps in place - could be a broken tab?
Old Nov 21, 2006 | 03:06 PM
ALLEGRO's Avatar
ALLEGRO
How does it unsnap?
Old Nov 21, 2006 | 04:16 PM
BrianWe's Avatar
BrianWe
Are you talking about the door handle itself? If so, you'll have to pull off the panel as the handle bolts in from the back. Just follow the instructions on VE's website to remove it. It should take about an hour round trip.
Old Nov 21, 2006 | 05:35 PM
ALLEGRO's Avatar
ALLEGRO
Found the instructions on the VE site. Just unsnapped the surround, then reinstalled it. Now it is tight, looks great and:
ALL THE WORLD IS GOOD
Old Nov 21, 2006 | 05:37 PM
HummelS's Avatar
HummelS
Originally Posted by ALLEGRO
How does it unsnap?
From the Svc Manual:
1. Pull the door inside handle open to access the openings to the bezel locking tabs.
2. Insert a screwdriver in the lower opening. Tip the scredriver up while pulling on the bezel releasing the lower locking tab.
3. Insret the screwdriver in the upper opening. Tip the screwdriver down while pulling on the bezel releasing the upper and forward locking tabs.
4. Grasp the bezel firmly and pull releasing the rear locking tabs.
5. Remove bezel.
To Help with Door Bezel
