Question about Sta-Bil
Old Nov 22, 2006 | 07:09 PM
BLAZBYU's Avatar
BLAZBYU
Default Question about Sta-Bil
Since the Corvette has two tanks, how do you get equal amounts of Sta-Bil in each tank?
Old Nov 22, 2006 | 07:30 PM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
I put the Stabil in when my car is on empty, then fill it up. I then drive for 10-15 miles before putting it into storage. I've done it for years and never had a problem.
Old Nov 22, 2006 | 07:58 PM
FFIN90's Avatar
FFIN90
From: = From Toronto = 9/11/01 FDNY 343 Never Forget
CI 6-7-8-9-10 Veteran
St. Jude Donor '08-'09-'10-'11-'13-'14
Old Nov 22, 2006 | 10:47 PM
moserbe's Avatar
moserbe
Same here.
Old Nov 23, 2006 | 04:37 AM
That's what I do. Just bought a bottle and getting ready to do it to mine.
Old Nov 23, 2006 | 10:39 AM
BLAZBYU's Avatar
BLAZBYU
This still doesn't tell me how it gets in both tanks equally. By doing it on an empty tank you only treat half of your fuel. I would think you should put in half on an empty tank and after 10 gallons, put in the other half to treat the other tank. Does this make sense to anyone else?
Old Nov 23, 2006 | 11:25 AM
DevilDog II
Oldtimer
I could be wrong, but I thought that by putting the Stabil in an empty tank it would mix and go into both fuel cells. I'd be interested in knowing if the gas is used from both cells simultaneously as you drive or just one at a time. If it's only drawn from one cell at a time, I'd think that it might throw the car's balance or center of gravity off.
Old Nov 23, 2006 | 10:51 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I thought there was a pump that kept the tanks equal? it keeps mixing the fuel.
Right?
Old Nov 24, 2006 | 09:19 AM
JTJ's Avatar
JTJ
Found a good article re: C5 fuel tanks on the ZO6 websiteThis should help)
Mr. Y2000: The C5 Corvette has two fuel tanks, left and right hand. The left hand tank contains the electric fuel pump that supplies fuel to the engine. The right hand tank has a pump, which transfers fuel from the right tank to the left tank. The pump in the right hand tank has no moving parts and is not really a pump. It is a siphon device that uses fuel pressure from the left hand pump to start a siphon that transfers fuel from the right hand tank to the left hand tank. In order to create this siphon, the fuel line that goes to the engine splits and a small amount of pressure is routed to the right hand tank to start the siphoning. The fuel that is being siphoned is routed through another hose to the left hand tank. If the left hand tank is full, the fuel transfers back to the right hand tank through the large filler tube located at the top of the tanks.
The idea is to always keep the left hand tank full whenever there is fuel in the right hand tank. When the fuel gauge reaches a half tank, the right hand tank is empty and the left hand tank is full. Both tanks have a float and sender that measures the fuel level in the tank. These signals go to the Powertrain Control Module (PCM) which interprets the information and sends a signal to the Body Control Module (BCM) which then sends a signal to the fuel gauge in the Instrument Cluster.
Because of the variation in tanks and sending units, the PCM doesn't always read the actual fuel level in the tank. Above or below preset voltage limits, the fuel level is estimated. The voltage limits for each sending unit, right and left, are set to represent "full" and "empty." When one or both tanks have exceeded the preset limits, either "full" or "empty," the system is estimating the actual fuel level. This happens when both tanks are full, gauge is "full;" when the right tank is empty and the left tank is full, "half" on the gauge, or when both tanks are empty, gauge is at "empty."
This estimating strategy and the physical layout of the system results in an unusual fuel gauge characteristic that may be noticeable to some people. When the fuel level is at or near half tank, the right hand tank is empty and the left hand tank is full, so the system is estimating the actual fuel level. Because of the siphoning system, when the car sets without running, the fuel level equalizes in the two tanks. When the car is first started, the system is actually reading the fuel level in both the right and left hand tanks. After running for several minutes, the fuel in the right hand tank has been transferred to the left hand tank, leaving the right hand tank empty and the left hand tank full. The change in the fuel levels results in the system changing from reading the actual fuel level to estimating the fuel level. This change results in the fuel gauge reading actually indicating more fuel than when the car was first started.
One of the common concerns with the Corvette is the fuel gauge goes to "empty" intermittently. First, let's discuss why this happens. As previously mentioned, the system estimates the fuel level at certain times. When the signal from the left hand sender is above the preset voltage limit, the system estimates the left hand tank fuel level to be full. When the signal from the right hand sender is below the preset voltage limit, the computer estimates the right hand tank fuel level to be empty.
In this situation, left tank full and right tank empty, the computer estimates the fuel level and sets that gauge at half tank. Once the fuel level in the left hand tank goes below the preset voltage limit, less than full, the computer begins reading the actual fuel level and setting the gauge accordingly. At this time the computer expects to see the voltage signal from the right hand tank stay below the preset limit that indicates empty. The problem comes from the fact that the signal from the right hand tank does not stay below the preset limit. When the computer sees the right hand signal voltage exceed the preset empty limit, it assumes that there is a problem in the fuel transfer system, which is a possibility. When this condition exists, the computer software turns on the Check Gauges light and commands the fuel gauge to the empty position. The logic for this is, if there were a problem with the fuel transfer system and fuel was not being transferred from the right hand tank into the left hand tank, you could have the gauge indicate half tank, when then the left hand tank would be empty and the right hand tank would be full. In this situation you would run out of gas and be walking.
On some Corvettes the situation that is occurring now is the result of the right hand sending unit being attacked by compounds within reformulated gasoline. This condition manifests itself as an erratic voltage signal from the right hand sending unit. In the above scenario, left tank full and right tank empty, gauge at half, the computer looks for the voltage signal from the right hand tank to stay below a preset level. The erratic voltage signal caused by the reformulated gasoline causes the computer to think there is fuel in the right hand tank when there is not. When this happens the computer software turns on the Check Gauges light and commands the fuel gauge to empty. GM has issued a revised computer software, for 1999 through early 2002 models, that raises the right hand preset voltage empty limit to prevent the erratic voltage signal from causing this situation. While it has proven to be an effective solution, it has not corrected the concern in all instances.
Another possible resolution is to use Techron fuel system cleaner. This has also worked in many, but not all cases.
__________________
Old Nov 24, 2006 | 09:26 AM
TomZ's Avatar
TomZ
Originally Posted by FFIN90
Me, too.
Old Nov 24, 2006 | 09:27 AM
DevilDog II
Oldtimer
__________________
In summation, the right tank doesn't always know what the left tank is doing.
Old Nov 24, 2006 | 11:19 AM
AEmedic's Avatar
AEmedic
To Question about Sta-Bil
