Please settle this arguement
Old Nov 26, 2006 | 12:07 AM
rkhegler's Avatar
rkhegler
Originally Posted by Lew W
I just got a set of chrome lug nuts for my 2002. Told my buddy I was going to put them on one by one without jacking the car up i.e. take one off put the new one on. He said it will create problems and I cannot imagine how it can. Comments solicited and appreciated.
Drink more beer. That will settle the arguement.
Old Nov 26, 2006 | 12:54 AM
ja03c5's Avatar
ja03c5
Not a problem...go for it.
Old Nov 26, 2006 | 02:03 AM
67weaver's Avatar
67weaver
IMO theres no problem, just as long as you torque it right you should be fine, just check it after you drive it
Old Nov 26, 2006 | 05:24 AM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Originally Posted by mph1972
I have done it a couple of times and I have NEVER had any problems!
Old Nov 26, 2006 | 07:47 AM
b98's Avatar
b98
I would not do it . The problem is quite clear to me.
Old Nov 26, 2006 | 11:31 AM
tsts's Avatar
tsts
I see said the blind man to the man who could not hear!
Old Nov 26, 2006 | 11:38 AM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
Screwing with lug nuts should ONLY be done by a trained professional.
Old Nov 26, 2006 | 05:58 PM
jay'szo6's Avatar
jay'szo6
My brother used to work at America's Tire Co for 4 years. I've had them put on 4 or 5 sets of wheels/tires for me. I get to watch since my brother worked there. And they always torque the lugs before the car is fully on the ground. So the car is still on the lift suspended, but with the tires hitting the ground. Never asked why. But that's how they always do it. I wouldn't think it would make a difference.
Old Nov 26, 2006 | 06:32 PM
TEXHAWK0's Avatar
TEXHAWK0
The only reason I would not do it that way is because I like to tighten the lug nuts down evenly, and you cannot do that with one of the lugs off.
At the very least, after I had gotten all the lug nuts changed out your way, I would back off of all the nuts, and retorque them in sequence.
Old Nov 26, 2006 | 06:53 PM
Vega$Vette's Avatar
Vega$Vette
If you do not torque the in the proper sequence you will lose 5 rwhp per wheel.
Old Nov 26, 2006 | 07:20 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
You buddy's comment might be correct if the car depended upon equal wheel-to lugnut-seat force for centering the wheel (i.e., stud-centric). However, all modern Corvettes use hub-centric wheels, so the lug/stud play no role in centering the wheel. On hub-centric assemblies, the weight is supported by the hub and center hole on the wheel. The lugnuts are only there to hold everything snug. The wheel is certainly not going to slip off the hub of a stationary vehicle when held on by 4 of 5 properly torqued nuts.
Just do it.
