Please settle this arguement
Nov 24, 2006 | 06:47 PM
Nov 24, 2006 | 06:49 PM
2017 C7 of the Year Finalist
St. Jude Contributor
I would think that would work ok
Torque to 100
Do it AGAIN after you drive the car also
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
I don't see any issues - just make sure that you torque your new lugs to 100 lb.ft. and you should be good to go.
Cruise-In VIII Veteran
St. Jude Donor '07
I have done it a couple of times and I have NEVER had any problems!
Nov 24, 2006 | 06:51 PM
No big deal IMO as long as you torque them properly after.
Nov 24, 2006 | 06:56 PM
Quote:
Originally Posted by Lew W
He said it will create problems and I cannot imagine how it can.
Such as???????
Nov 24, 2006 | 07:19 PM
No problem..
Nov 24, 2006 | 07:20 PM
I cannot see how that would cause any problems. I would ask your buddy to clarify his statement.
Nov 24, 2006 | 07:21 PM
St. Jude Donor '05, '12-'13, '15-'16, '21
Did he say what the problems would be? None that I know of. You should be fine with the right torque.
Nov 25, 2006 | 12:22 AM
Don't see a problem either as long as you torque them down to the right setting.
Nov 25, 2006 | 01:07 AM
Problems?
Like if you take one off the rest with break off and your tire will go flying because of the immense pressure.
Nov 25, 2006 | 01:09 AM
I couldn't see any problems as a result of doing that.
Nov 25, 2006 | 01:11 AM
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
You'll be fine! I used to install wheels and tires for a living @ Super Shops (back in the day!)
The main thing is after about 10-20 miles you re-torque them to 100 lbs. this is the clincher do not forget to do this after a short while!
I would thank your friend though at least he is concerned for your safety but again you'll be alright!
Thanks,Matt
Nov 25, 2006 | 06:53 AM
Nov 25, 2006 | 07:11 AM
Oldtimer
Quote:
You shouldn't have any problems, but make sure that you use a torque wrench.
Nov 25, 2006 | 07:22 AM
St. Jude Donor '06-'07
Since he's so knowledgeable on the subject have him list all the negative possibilities for you.
Personally, I've always "cracked" them with the tire on the ground and then raised the wheel for final removal. When I tighten them their firmly snug, wheel raised, then I lower the car and torque to 100 foot pounds.
Never a problem....I think your friends jealous, he probably drives a Mustang...
Nov 25, 2006 | 07:37 AM
St. Jude Donor '08
It will make Baby Jesus cry.
Nov 25, 2006 | 09:48 PM
Nov 25, 2006 | 10:14 PM
Just do it!!
Nov 25, 2006 | 11:38 PM
The only problem, you thought of it, and he couldn't.
