Door Insert Thingee
Old Nov 24, 2006 | 09:08 PM
LoJo's Avatar
LoJo
Default Door Insert Thingee
OK...sheesh....I am now missing the "insert" which is just underneath the door handle (interior). This is a three "pronged" insert. Somehow mine came loose and whomever got in my car last time, when they opened/shut the door, it fell out. Gone. Grrrr.
How can I get a replacement for it? I went to GM parts, but that site is hopeless!
Any ideas..any help? Thanks.
Btw...I have an '00 Vette...not that it's really an issue, as I assume this part is similar on all the c5's.
Old Nov 24, 2006 | 09:11 PM
devnull's Avatar
devnull
Scientific Negotiator
St. Jude Donor '07-'08-'10, '14
I would think that any dealer should be able to come up with one...
Old Nov 24, 2006 | 09:18 PM
doug doo wop's Avatar
doug doo wop
My '02 driver side kept falling out so I finally glued it. It always fell inside the car, under the seat-check it out first.
Old Nov 24, 2006 | 09:24 PM
TEXHAWK0's Avatar
TEXHAWK0
Try Ecklers.
I think they are $425.
cruisemon's Avatar
cruisemon
The dealer nearest you probably stocks them. I paid a little over $4 a pair, but I have a buddy at the dealership. Others paid $4 apiece, some paid $6. You can also get them from supporting vendors (Bean, etc.). Usually one of the locking tabs has been bent or broken off and they fall off. Hope you didn't glue it in TOO well, especially if it's on the passenger side 'cuz it's about time for the passenger side window regulator to stop working. You're going to try the door slam with the down button pressed and it may work for awhile, but then you're going to need to change the regulator or the motor and THEN you're going to have to dig out a glued in cover.
Charlie
Old Nov 25, 2006 | 12:19 AM
Your local Chevy parts department should be able to look this up for you and get you the part. If they can't find it, give Bob at Fichtner Chevy a call.
Old Nov 25, 2006 | 06:56 AM
slammedwhitec5vert's Avatar
slammedwhitec5vert
Dealer Cheap!!!!! about 3.00
Old Nov 25, 2006 | 07:00 AM
Frozenfire's Avatar
Frozenfire
The first time that happened to me I purchased a replacement at my dealer. When the replacement one fell out a few months later, I was lucky enough to recover it and just glued it back on.
Old Nov 25, 2006 | 07:33 AM
HMannini's Avatar
HMannini
Cruise-In X Veteran
St. Jude Donor '09
It's GM Part#10279471 Door Panel Access Plug.
Old Nov 25, 2006 | 07:37 AM
inospdn's Avatar
inospdn
Like these guys said ," check under the seat ,1st" .
I did see a couple of ads for these on Ebay last night, under $5 with postage included.
Old Nov 25, 2006 | 08:15 AM
DeeGee's Avatar
DeeGee
Try the dealer. Shipping is more expensive than the part
Old Nov 25, 2006 | 09:47 AM
RatedX's Avatar
RatedX
From: Spring Hill, Florida Life is all about new beginnings;...TRY ONE!
Originally Posted by TEXHAWK0
Try Ecklers.
But there is an 8 month wait!
Old Nov 25, 2006 | 10:02 AM
rodknock's Avatar
rodknock
Corvette Central has them, they are a supporting vendor.
Old Nov 25, 2006 | 10:04 AM
eddie44's Avatar
eddie44
St. Jude Donor '03
Ebay is your friend (no not my listing)
http://cgi.ebay.com/ebaymotors/2-COR...54586725QQrdZ1
Old Nov 25, 2006 | 01:53 PM
cruisemon's Avatar
cruisemon
Call that dealer and quote me: : :
Call another dealer. The first one just doesn't want to mess with ordering the part. Special ordered mine maybe two months ago and had them at the parts counter in two days.
Charlie
To Door Insert Thingee
