[Z06] Lowering a Z06
Old Nov 30, 2006 | 09:01 PM
TwistedAphid's Avatar
TwistedAphid
Default Lowering a Z06
I will be getting a 2003 Z06 soon.
This car will just be a toy and not driven that much, mostly on weekends.
I like the lowered look, but I am concerned about the car's ground clearance.
I still want to be able to go over normal size speed bumps without dragging.
How much (if any) can I lower the car?
Old Nov 30, 2006 | 09:07 PM
SliderZ28's Avatar
SliderZ28
Until it drags ...but I'd stick with the stock lowering bolts. You can go all the way with them and still have moderate clearance
Old Nov 30, 2006 | 09:12 PM
TwistedAphid
I assume you mean to adjust the stock bolts without cutting the bushings, etc. Correct?
I've seen lowering bolt kits that are very cheap, what are the advantages to these? Just able to go lower?
Steve Theodore's Avatar
Steve Theodore
Even at bone stock ride height (3" tire to fender gap...very unsightly I know) I am amazed at how low this car is. I hit the rubber molding under the bumper quite regularly despite being careful. You'll really notice how low the car is when you go to lift it for any routine maintenance too!
Old Nov 30, 2006 | 09:28 PM
TwistedAphid
I also plan on getting some larger aftermarket wheels, maybe this will also help with the fender gap.
Old Nov 30, 2006 | 10:13 PM
NW_Vettes's Avatar
NW_Vettes
Actually larger wheels make the gap look worse sometimes. The profile on the tires has to be smaller and this gives the visual affect of being a bigger gap to me. Only way to fill the gap is to have a larger profile tire (larger diameter, bad idea). I would lower it on stock bolts and see what you like
Old Nov 30, 2006 | 10:26 PM
03 Z-oh-6's Avatar
03 Z-oh-6
I agree!!! I'm on stock height and I hit the rubber molding all the time!!! I've wanted to lower the vette since day one, but I can't bring myself to do it. If I lowered it on stock bolts, I think the rocker panels would start scraping in certain areas, screw that!
Old Dec 1, 2006 | 11:26 AM
jfrc's Avatar
jfrc
my front lowering bolts are removed
and its still not low enough for me
about another 1 - 1.5" would be perfect
any tricks, other than coilovers?
Old Dec 1, 2006 | 12:11 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi dlh1974 -
In my experience, you can lower to the stock limits without causing too much added aggravation -
Realistically, the air-deflector under the nose of the car will scrape occasionally on even a stock height car - so this part will make more contact when you go the approx. 1" on the stock limits.
Since it is so easy to lower it and then raise it back up - I would suggest going to the stock limits and try that for a while.
If you go with aftermarket rear bolts and cut bushings up front, you WILL get a much harsher ride and will put the rockers more at risk on peaks found in pavement transitions (like the top of a sloping drive where the garage pavement levels off).
I have never scraped the front fascia, radiator supports, or the rockers on either of my cars as a result of lowering on stock bolts.
Any more, I think the cars that have "as-delivered" ride height adjustment look funny.
best regards -
mqqn
Old Dec 1, 2006 | 01:30 PM
Steve Theodore
It reminds me of one of my other vehicles...the Toyota 4Runner!
Originally Posted by mqqn
...Any more, I think the cars that have "as-delivered" ride height adjustment look funny...
Old Dec 1, 2006 | 01:59 PM
ICaughtVetteFever's Avatar
ICaughtVetteFever
Yes, you can get a VBP front spring, you can drop as far as you want then, just like coilovers. I have one I was going to use, but got a set of coilovers I may be using instead, let me know if you are interested.
Old Dec 1, 2006 | 09:17 PM
IsItFast's Avatar
IsItFast
I was totally happy with mine lowered on the factory bolts until I got new rims/tires. I belive the problem that the Kumho tires are more rounded over on the edges so it give the illusion that is sits higher. So I just went extreme and removed the front bolts and longer rears. I drag pretty good about one a month on odd driveways and parking lots. And I am always really careful going in at angles and such. But I haven't torn anything up; I just get used to that aweful scraping sound.
Like the others said, try the stock bolts out. You can lower it in about 1/2 an hour or so. But give it a few days for the shocks to settle in to the new height. Below is my now:
Old Dec 2, 2006 | 12:14 AM
TwistedAphid
Thanks for all the info!
Old Dec 3, 2006 | 02:48 AM
Vetteoholic's Avatar
Vetteoholic
I was thinking of doing that because of the gaps In the wheel wells. Two reason's why I didn't #1= I don't want to be scaping the rubber piece any more than I already do. #2= If you lower the car It will most likely be stiffer and there would be less weight transfer to the rear wheels during take off~which would mean less traction which Is limited anyway. -Just my opinion *Lowered does look better though
Old Dec 3, 2006 | 03:53 AM
Twil1ght's Avatar
Twil1ght
According to the engineers who developed the vehicle, 20mm down is the sweet spot in the stock shock's valve specifications for optimum handling. Any further lowering is detrimental. This comes out to roughly 6 turns on the adjustment bolts.
Old Dec 3, 2006 | 07:55 AM
Z28TOZO6's Avatar
Z28TOZO6
I thought mine was stock height until I parked next to a guy with the same year Z and his was higher than mine. I have no idea how much they lowered it although its not enough yet, in my opinion, but I fear going lower will cause me problems as I am in some hilly country.
Old Dec 3, 2006 | 07:59 AM
spdislife's Avatar
spdislife
Going beyond that may have an adverse effect. Also if you plan to track the car, based on a recent discussion here, going too low has a negative impact on air flow under the car.
To Lowering a Z06
Old Dec 3, 2006 | 04:29 PM
IsItFast's Avatar
IsItFast
I don't track my car (auto or drag) so I did it just for looks. I don't push my car enough on the street to worry about the effects myself. But if all you guys push your car to the limit on the streets (as everyone talks like they do) than don't lower it past the factory bolts! Other than a rougher ride I don't think anyone can say it makes a huge difference in handling for driving on the street.
Old Dec 3, 2006 | 04:38 PM
Twil1ght's Avatar
Twil1ght
Well it is going to depend on how you drive it. If you defeat the capabilities of the shocks by dropping it to low-rider status and you put the car in a corner and encounter a surface irregularity - via con dios. If you aren't interested in performance driving, then by all means drop it down and put some switches in it.
Old Dec 3, 2006 | 04:51 PM
IsItFast's Avatar
IsItFast
Adding a thousand pounds of pumps and batteries is a little more extreme than just lowering the car an extra half an inch. I drive my car hard on the street and feel just as comfortable with it lowered as I did with it stock. If you are pushing the limit on the street so far that you can notice a difference in an extra half inch you are going to end up in the ditch even with stock ride height.
