The one and only time my light came on it was because of the gas cap. I took it off, put it back on, and clicked it around for 360 degrees and the light went off. I do that every time now and I've not had the light come back on.
But it could be so many other things. Check the codes to be sure.
While driving home last night, I turned on the left turn signal and the Check Engine light went out and I got a fast blinking signal. When I got home and checked, the left DRL/turn signal was out.
