[Z06] Please help with 2001 zo6
Old Dec 3, 2006 | 03:28 PM
whitebullet7's Avatar
whitebullet7
Default Please help with 2001 zo6
whenever i pull the oil deep stick out and i saw the white stuff on there,it's looked like water and oil mixed up but i never short on coolant.i took the oil filler cap off when the engine running and there is smoke coming out of it
please let me know
thanks alot
Old Dec 3, 2006 | 04:32 PM
Twil1ght's Avatar
Twil1ght
Smoke from the filler cap is probably not a problem when the vehicle is hot. Condensation on the dip stick could be as simple as it's not making a good seal when inserted - or as major as a failing head gasket.
Old Dec 3, 2006 | 06:25 PM
bob guzzy's Avatar
bob guzzy
Default condensation
Usuall found this time of year, on dipstick, under filler cap, from short trips, the engine dosen't get up to temp long enough to evaporate it, take it on a good ride, when you can....
Old Dec 3, 2006 | 09:06 PM
whitebullet7
even in the morning i start up the car,there still smoke come out and my car have 75k on it
thanks
Old Dec 4, 2006 | 10:02 AM
Road machine's Avatar
Road machine
Keep a very close eye on your coolant level for a while. Unless it is condensation, you would loose coolant if you have a bad head gasket or a crack somewhere. It is most likely condensation though. You would be very surprised by how much condensation you can get in any motor. You could also have a problem with the pcv system. This system is meant to get any blow-by or condensation out of the crankcase and into the cylinders, then out through the exhaust. Unless you see coolant loss, I would not worry.
Old Dec 4, 2006 | 11:32 AM
81c3's Avatar
81c3
which brings up the 3000 mile oil change intervals???? I dont want alot of condensation in my oil!
Old Dec 4, 2006 | 02:32 PM
whitebullet7
thanks
Old Dec 5, 2006 | 07:54 AM
Vetteoholic's Avatar
Vetteoholic
I would change or have my oil & filter changed & see what happends. You may need a system flush & while your at It If you haven't changed the other fluids In a while, you should have the entire system flushed and refilled. Not sure If that's the problem but It's good to do anyway.
I'm sure It's nothing major. Best of luck
Old Dec 5, 2006 | 03:26 PM
whitebullet7
i did change the oil,filter and the oil looked normal to me.how do you flush the engine?
Old Dec 5, 2006 | 05:13 PM
Vetteoholic
I don't know the details because I had It done, I didn't do It myself. All I know Is they were using this machine to force the oil out & Into the oil pan. Your required to have this done If your using synthetic and decide to use regular motor oil & vice versa. I had mine done at Jiffy Lube for $70.00 + tax. I would ask them about It.
Old Dec 6, 2006 | 03:04 AM
whitebullet7
thanks
i will have them to do it for my car too
Old Dec 7, 2006 | 09:15 AM
Vetteoholic
thanks
To Please help with 2001 zo6
