Mini Ramps
Old Dec 5, 2006 | 01:29 PM
deadbolt67's Avatar
deadbolt67
Default Mini Ramps
Anyone out there have a pair of these?
http://www.rampconnection.com/plastic-car-ramps.shtml
I have lowered my C5 on the factory bolts and these look like a pretty decent solution for getting it up high enough for my jack. I wish they were a little wider, but believe they will work OK. I know of another company with something that appears to be a better solution, but they cost five times as much!
Anyway, I went ahead and bit. I figure I have blown much more than 29.00 + shipping on stuff before. I will report back on how they work out.
Old Dec 5, 2006 | 01:48 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
I'd be interested in hearing about that...
Peace
Chip
__________________
..................Click for
Old Dec 5, 2006 | 01:55 PM
NW_Vettes's Avatar
NW_Vettes
Or just buy some 2x12's
Old Dec 5, 2006 | 02:16 PM
deadbolt67's Avatar
deadbolt67
Been there before until I switched to a low profile NAPA jack. I can actually get the jack under the car, but it is a really tight fit.
Thought I would try something different and keep the garage from looking like a lumber yard.
Old Dec 5, 2006 | 02:32 PM
hotwheels57's Avatar
hotwheels57
...they're only 7 3/4" wide...
Old Dec 5, 2006 | 02:49 PM
deadbolt67's Avatar
deadbolt67
As I said in the original post, I wish they were wider.
My front Wide Ovals (265/40/17) have a tread width of 9.1", leaving between 5/8" and 11/16" hanging over each side.
Considering a 14" wide solution is over 170.00 shipped, I will give these a try. If they don't work out, I will give them to Goodwill!
Old Dec 5, 2006 | 02:53 PM
Dave68's Avatar
Dave68
2 and 3/4 inches may be high enough for low-pro jacks, but I doubt standard jacks will be able to fit under the front end. The width doesn't matter much if you lift with a jack and then place the car on jack stands, so if the height is okay for you, I say give it a try.
Old Dec 5, 2006 | 03:12 PM
Omega Man's Avatar
Omega Man
From: I speak the truth. Harsh but accurate. The Woodlands Texas
St. Jude Donor '09-'10
"Prevents moisture build up under cars for long storage"
What ever.
Old Dec 5, 2006 | 03:48 PM
460HP-YLO-JAKT's Avatar
460HP-YLO-JAKT
I have a set and they work great for getting car high enough to get jack underneath.
Old Dec 5, 2006 | 09:17 PM
silverbullit99's Avatar
silverbullit99
Hey,,,,, I was going to say that !! ........ for a fraction of the cost. and it is not high enough stack 2..
Old Dec 5, 2006 | 10:47 PM
jasons0147's Avatar
jasons0147
Car is going to be higher up in the air than that, since the cars frame is not on the ground to begin with.
Old Dec 5, 2006 | 10:51 PM
Ta-taaa's Avatar
Ta-taaa
Pretty cool...
Old Dec 5, 2006 | 11:01 PM
deadbolt67's Avatar
deadbolt67
According to the tracking number, they should arrive on Thursday. I will try both jacks; I have a NAPA low profile and a regular height jack. Maybe I will post a picture or two.
Old Dec 5, 2006 | 11:13 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
Please post pics. I use doubled 2x10s now also, but this product might be a player.
Old Dec 6, 2006 | 02:38 PM
Looks like those would work. Let us know how they do.
Old Dec 6, 2006 | 04:52 PM
NW_Vettes's Avatar
NW_Vettes
I think he meant that he still won't be able to go straight under the front bumper and lift at the cross member.
Old Dec 7, 2006 | 07:30 PM
deadbolt67's Avatar
deadbolt67
Default Pics as promised.
Overall I would say I am pleased. They do the job nicely, but I wish they were a couple of inches wider. However, that does not impact their functionality.
What was in the box:
This is what I had before using the ramps. My low profile NAPA jack would clear with me holding the air dam up, but it was a tight fit for sure.
Before driving up. I measured about 2" between the ramp surface and the air dam. I calculated the incline to be right at 9 degrees.
After driving up the ramps.
Bottom line: They work well and don't slip. Sure you can use a couple of 2x12's but I wanted something different that would not break the bank. Then again, modding fever always seems to break the bank.
I will try and get a shot using my standard jack sometime over the weekend. It is just too damn cold outside right now.
To Mini Ramps
