Need help with DIC code
Old Dec 6, 2006 | 12:53 PM
c5streak's Avatar
c5streak
Default Need help with DIC code
Got a P0492 this morning along with the CEL. Can't find this code anywhere on my lists. Any ideas? Thanks!
Old Dec 6, 2006 | 05:08 PM
c5streak's Avatar
c5streak
This happened on a drive after I washed out the engine comp. I cleared the code and drove around awhile and nothing came back up. Possibly water in a sensor or connector? Still can't locate P0492 anywhere.
Old Dec 7, 2006 | 07:16 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
I don't think that's a valid code, perhaps someone else can find it. Are you sure you read it correctly? Perhaps P0462? Anyway, watch for it so you can double check on the code number.
Old Dec 7, 2006 | 09:34 AM
c5streak's Avatar
c5streak
Yse! This cuold be a porbelm with lisdexia. Fortunately, the code has not come back. I'll have to wait and see. Thanks.
Old Dec 7, 2006 | 09:49 AM
dadvan99's Avatar
dadvan99
Cruise-In VII Veteran
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Oldtimer
I found this with a Google search.
P0492 Sec Air Inj Sys (bank2)
The computer does not see a change in the o2 readings when it turns the airpump on to test it.
Possible problems are a bad air pump (full of water?),a bad airpump relay, a bad check valve, a bad vac control solenoid that supplies vac to the air control valve,a vac hose problem, or a bad solenoid itself.
The airpump is located in the right front of the engine compartment.It should run when the engine is first started cold.
If you dont know how to check the system from this info then you will need to have your mechanic have a look.
__________________
Old Dec 7, 2006 | 12:24 PM
POK868's Avatar
POK868
hmmm.
Old Dec 7, 2006 | 12:54 PM
Stonecutter908's Avatar
Stonecutter908
I would suggest posting in the C5 Tech area.
Old Dec 12, 2006 | 03:58 PM
c5streak's Avatar
c5streak
Sorry for the delay,my PC crashed about an hour after I last posted. Thanks to a package from Mr. Dell, it's all good now. I think "dadvan99" has probably hit it right. I had just washed the engine comp when it threw the code. Everything is dry now and no more codes! Is this place
or what? Thanks again!!!
Old Dec 12, 2006 | 05:29 PM
jimbosr's Avatar
jimbosr
mine spit that code out saturday and did a reset and it hasnt come back
To Need help with DIC code
