All-aluminum chassis?
Old Dec 6, 2006 | 07:00 PM
TopFuelTim's Avatar
TopFuelTim
Default All-aluminum chassis?
I read the December '06 Motor Trend magazine comparing Viper, Corvette and Mustang. Said the Z06 they tested had an all-aluminum chassis. I was kind of under the impression the chassis was steel. Is Motor Trend correct?
Incidentally, the Corvette "won" overall. Go figure .
Tim Glover
Old Dec 6, 2006 | 07:08 PM
dagon138's Avatar
dagon138
Only the C6 Z06 is, the C5's and the non-Z06 C6's are steel.
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
C6 Z06 chassis is all aluminium
Old Dec 6, 2006 | 07:13 PM
hotwheels57's Avatar
hotwheels57
...and it a hydro formed aluminum aluminum chassis, meaning less welds to fail and less weight, more structural strength...
Old Dec 6, 2006 | 07:24 PM
TopFuelTim's Avatar
TopFuelTim
Default I learn something new every day
Way cool!
Old Dec 6, 2006 | 08:18 PM
Vetteoholic's Avatar
Vetteoholic
Indeed It Is my friend Ofcourse the Z won. It's the fastest, and most comfortable~ SUPER
Old Dec 6, 2006 | 08:24 PM
batsallover's Avatar
batsallover
GM definitely spent some $$$ on the chassis. Reading about the C6 Z never ceases to amaze me.
Old Dec 6, 2006 | 10:15 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
Nope. I don't like it at all. I'll just keep my C5 with steel frame and "buggy springs" Just kiddin' I do appreciate some of the Technology in C6. Just can't get past the "Body."
Old Dec 7, 2006 | 12:02 AM
Vettman 1's Avatar
Vettman 1
Perhaps someone will mount a C5 body on a C6 chassis
Old Dec 7, 2006 | 12:28 AM
Ol'55's Avatar
Ol'55
I'm sure we'll see that "Resto" project cross the block at a Barrett-Jackson some time in the future. I've said it before in here I'd like to see that done.
Old Dec 7, 2006 | 12:33 AM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
The C6 body is basically mounted to a C5 chassis.
Both the C5 and C6 chassis are built with hydroformed steel tubing.
Old Dec 7, 2006 | 12:40 AM
POK868's Avatar
POK868
just on c6 z06
Old Dec 7, 2006 | 07:27 AM
Great way to save some weight and still be strong structurally.
Old Dec 7, 2006 | 08:24 AM
AU N EGL's Avatar
AU N EGL
Close but not quite.
The C6 has a 1" longer wheel base.
The C6 has a 1 1/4" narrower track( center of rear wheel to center of rear wheel )
the exterior of the C5 is larger then the C6. But the C5 is 1" lower then the C6 on stock ride heights
To All-aluminum chassis?
