Headlight door trouble - help!
Old Dec 8, 2006 | 12:48 AM
VettesRule's Avatar
VettesRule
Default Headlight door trouble - help!
One of my headlights clicks as it is lowering. After it is fully down, something keeps turning.
I manually raised the door and it works ok but after lowering it to the lowest postion it doesn't come up on a positive stop.
Anyone repaired this themselves? It looks like the motor / drive assembly is replaceable.
Any help is very appreciated.
Old Dec 8, 2006 | 12:55 AM
DeeGee's Avatar
DeeGee
Your plastic headlight gears have stripped. The noise you're hearing is the gear motor turning but the gears are not making contact. Its a common problem and you need to replace the old ones with brass gears.
You'll find all you need to know in this sticky. Run down to the section on headlight gears.
http://forums.corvetteforum.com/showthread.php?t=984927
jbauch357's Avatar
jbauch357
damn, beaten by seconds from across the pond!
look in the general info sticky at the top of this forum, it will tell you everything you need to know about replacing your worn out plastic gear with a more robust brass one...
Old Dec 8, 2006 | 01:04 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
http://forums.corvetteforum.com/show...589&forum_id=1
Old Dec 11, 2006 | 02:32 PM
VettesRule's Avatar
VettesRule
Thanks Guys!!
Old Dec 28, 2006 | 06:28 PM
VettesRule's Avatar
VettesRule
I used the brfranken replacement gear and had success. I did remove the entire headlight assembly and the job was easy.
One trick I found was that the electrical connector is easily removed by sliding it off a slotted peg toward the rear of the car. Once removed from the peg, it is easily separated.
It is about a 30 minute job but the epoxy takes 24 hours to cure. Another trick I used was to hold the gear cover tight to the case by wedging a few popsicle sticks between the cover and the headlight frame overnight until the epoxy was dry.
Old Dec 28, 2006 | 08:58 PM
indieaz's Avatar
indieaz
Definitely use brent franker's gears. Another common problem not address by some of hte ebay "rebuild kits" is that the plastic housing for the gear (that actually turns the gar) is also often broken. If i had gotten one of the ebay gears that would have only fixed half the problem and i would still ahve a non functioning headlight.
To Headlight door trouble - help!
