check engine
Old Dec 8, 2006 | 06:49 PM
r1_123's Avatar
r1_123
Default check engine
i was wondering how to check codes and turn off check engine light.
? thanks in advance
Old Dec 8, 2006 | 07:23 PM
pistolpete817's Avatar
pistolpete817
Turn the key to the ON position but do not start the car.
On the DIC control, push and hold options.
While holding Options, push Fuel four times.
The display wil begin an automatic display cyle.
The suffix H indicates an historical code that is no longer active.
A indicates an active code.
Press Reset to enter a manual cycle.
Press Options to walk through each module.
To reset a code, press press and hold Reset until No Codes is displayed.
Then move on to the next module.
Hope this helps.
