[Z06] Afternoon Project
Old Dec 10, 2006 | 11:26 PM
electronbluec5's Avatar
electronbluec5
Default Afternoon Project
I ordered this set of Wilwoods from Tbyrne a couple of weeks ago and got an incredible deal on them. Fast service and very helpful. Thanks to those at Tbyrne. I tried to get them installed yesterday at the local chevy dealer and the tech never showed so I decided to do it myself today. The whole install only took about 4 hours. I put Wilwood stainless lines on as well. I was a little intimidated but the most dificult part was getting car up on jack stands. I strongly recommend this mod to anyone who plans on some track time. I went out on the interstate and ran it up to about 90mph and braked to 70mph about 5 or 6 times to try to break them in a little and it felt very solid. Got off the interstate and came to a stop and had smoke pouring out of the wheels. Nothing wrong, just a few oils and brake fluid burning off. But I'm not saying it didn't worry me for just a sec.
Old Dec 10, 2006 | 11:38 PM
spdislife's Avatar
spdislife
They look impressive. What was the cost of that total package in the pics?
Old Dec 10, 2006 | 11:42 PM
electronbluec5
I'm not sure I'm supposed to say due to the huge discount Tbyrne is offering. Give them a call and they will hook you up.
Sorry
Old Dec 10, 2006 | 11:45 PM
RonVette2's Avatar
RonVette2
Very nice looking, looks like a nice set-up.
Old Dec 10, 2006 | 11:49 PM
spdislife's Avatar
spdislife
Well if the discount was just for you I can understand your apprehension. Same token if they didn't specifically tell you to keep the price quiet, then......why not share with fellow Z owners?
Old Dec 10, 2006 | 11:54 PM
DPG's Avatar
DPG
St. Jude Donor '06
looks like a very nice kit.
Old Dec 10, 2006 | 11:55 PM
electronbluec5
The brake setup was just over $3200 shipped. All said and done it cost me about $3250 installed.
Old Dec 10, 2006 | 11:58 PM
spdislife's Avatar
spdislife
Thanks Appreciate the info.
Post some pics with the wheels on if you get a chance.
Looks great
Old Dec 11, 2006 | 12:06 AM
Steve Theodore's Avatar
Steve Theodore
Any noticeable weight reduction compared to stock? Looks terrific!
Old Dec 11, 2006 | 12:17 AM
aldrichc5's Avatar
aldrichc5
Great looking setup.
Old Dec 11, 2006 | 12:22 AM
electronbluec5
I think the overall weight is a little less but not much. The front rotors even with the aluminum hats are about as heavy as the stock fronts. I think the calipers are lighter than the front stockers but about the same in the rear. I didn't weigh them but having done the install myself those are my reflections.
Old Dec 11, 2006 | 12:23 AM
RonVette2's Avatar
RonVette2
Looks like some nice suspension upgrades under there too
Old Dec 11, 2006 | 12:27 AM
spdislife's Avatar
spdislife
There was a thread about a month ago and if I remember correctly the savings was around 12 lbs for all 4 rotors. Caliper difference I have no clue.
Old Dec 11, 2006 | 12:30 AM
RonVette2's Avatar
RonVette2
12 pounds savings, that seems like a lot to me, I'm going to go and try to find that thread. If you can find it first please post it.
Old Dec 11, 2006 | 12:40 AM
spdislife's Avatar
spdislife
http://forums.corvetteforum.com/show...tweight+rotors
Post # 26....
also on the c5 general sticky that's titled Weights , ratios, strength etc, there's a list of things to reduce weight. There it states 20 to 30 lbs for aluminum hat rotors, but I think that refers more to the titanium ones
electronbluec5
I seriously doubt there is a 12lb difference. Maybe if you left off the rotors and just installed the hats. Then I could see 12lbs.
Old Dec 11, 2006 | 12:46 AM
spdislife's Avatar
spdislife
If you got the aluminum hats, which I'm assuming you did, it could very easily be 2 to 3 lbs per rotor. I've also seen a number of vendors make the same claim.
To Afternoon Project
Old Dec 11, 2006 | 12:50 AM
electronbluec5
Aluminum Hats in front but steel hats in back because of the parking brake drum. I would say that there is a 2lb max difference between the fronts. I could be wrong. I'm know trying to make you believe that my two hands can measure differences in weight down to the ounce but I can usually tell a couple of pounds.
Old Dec 11, 2006 | 12:59 AM
spdislife's Avatar
spdislife
That would be about right. My understanding is every pound of unsprung weight is equivelent to 4 pounds of static weight. Using round numbers, if you can save 10 lbs on all 4 rotors it's like saving 40 lbs of static weight. For grins I checked out titanium rotors and the weight savings is almost 40 lbs for all 4, problem is the cost. About 4,000 for a set of 4.
Old Dec 11, 2006 | 01:02 AM
RonVette2's Avatar
RonVette2
I wish we could have known about your afternoon job before hand, I would have really liked to know what the exact weight difference between the stock "Z06" rotors and those new ones that you bought were. I have looked up the titanium rotors and they are $1,000 each rotor. and the matching calipers are almost a grand a piece too, easily add up to $7-$8 grand for a complete set-up, but with the huge noticable weight difference (documented) they are also claiming a difference in stopping distances of something like:
Stock 60 MPH to zero 135 - 145 feet
Ti set-up 60 MPH to zero 75 - 85 feet
And a lot less heat build up and quicker cooldown,
But that is a lot of cash.
Sorry to get sidetracked on your thread. That is a very nice set-up that you got, and a great price, and it looks killer.
