Question about Wheel Bearings
Old Dec 11, 2006 | 09:08 AM
IDM's Avatar
IDM
Default Question about Wheel Bearings
I haven't had much experience with these.
My C5 has the passenger front one that is bad. What is the likelyhood that another wheel bearing will go bad soon? Why would one go bad and not the others? Are the fronts more likely to go out than the rears and should I change the drivers side front at the same time?
Very expensive things seem to be breaking on my C5!
Thank you
Old Dec 11, 2006 | 10:50 AM
Crunchking's Avatar
Crunchking
I had to replace both bearings on the driver's side at around 50k miles. I have 170k miles on my 98A4 now, and I haven't had any more problems.
Old Dec 11, 2006 | 11:47 AM
IDM's Avatar
IDM
Thank you for the info. I wonder what makes them go out on a certain side ?
Old Dec 12, 2006 | 11:28 AM
IDM's Avatar
IDM
anyone else?
Old Dec 12, 2006 | 02:43 PM
electronbluec5's Avatar
electronbluec5
I've got about 45,000 miles on my 03 Z06 and I am going to be replacing the Pass front wheel bearing soon. I drive my car like it's meant to be driven so I'm not too suprised that it needs to be replaced.
Is there a difference between an Autozone part and a GM part when it comes to a wheel bearing? I got a price of $160 from Autozone; how much is the GM part?
Old Dec 12, 2006 | 02:44 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
I would just replace them as they go. You can do it yourself with the right tools.
Micah
Old Dec 12, 2006 | 03:08 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Do two at a time, 2 f or 2 r. Check the suspension busings while you are in there and see if they are bad. Sometimes a failing bushing will lead to bearing failure...
Peace
Chip
__________________
..................Click for
Old Dec 13, 2006 | 09:12 AM
IDM's Avatar
IDM
GM = Double the price. I'd be pissed if I had a 03 zo6 with 45k miles and a wheel bearing going out seriously!
Old Dec 13, 2006 | 09:58 AM
AU N EGL's Avatar
AU N EGL
If one bearing is going the other will sure to follow. replace them both. Use Autozone. The autozone bearings are made by Timken, same as GM but much less money.
Old Dec 13, 2006 | 03:07 PM
vms4evr's Avatar
vms4evr
The GM, Autozone, Carquest are all the same part, made by Timken. They just come in different boxes with different prices. The GM rear I was quoted at $430. Carquest $260, and Autozone $162.
The drivers side rear on my 02 Z06 with 30K miles started going bad. But I autocross and track the car with r-compounds so there is a lot of stress on them. So for me they are just wear and tear items associated with driving the car hard.
They are sealed units and even on a daily driver they just go sometimes. I just replaced the failed one and will not do them in pairs. That's your call. The fronts are much easier to replace than the rears. The only tools you'll need that you may not have is a big-a$$ socket for the axle nut. 33mm or 34mm if I remember correctly. And a ball joint and/or tie rod seperator. Just take your time and torque everything down to the proper specs.
Old Dec 14, 2006 | 10:06 AM
IDM's Avatar
IDM
Thanks vms I agree since they are random in failure I will just replace the bad one for now and save as I have a lot of money that needs to go to the car in other spots
To Question about Wheel Bearings
