Good morning fellows, My HUD isn't working. It seems like there is no power to same. The owners manual say to check the fuse. In searching for the fuse, I failed to find one listed as HUD. Can anyone out here tell me Which fuse powers this. Hopefully this will fix my problem
Sorry can't help on the fuse. Its not listed in the manual. Maybe one of the guys who fitted their own HUD can chime in.
Of interest I had a similar problem and it turned out to be a dry contact on the brightness slider. I struggled for hours before I cycled the slider a few times and .. voila, up it came.
Dumb question but I guess you checked that it had not been adjusted too high or low out of the field of view?
Pierre
According to the wiring diagram, the HUD is powered from the IPC circuit (fuse 19) in the Instrument Panel Fuse block. Fuse block under carpet in passenger footwell (undeer the toe board).
However, if this fuse was blown your whole IPC would not be working, you'd have no tach, speedo, etc.
Display the DTC's on your DIC and post them here, as they may point to the problem. Otherwise take a look at the HUD control switch panel as that may be the source of the problem.
