Pressure washing?
Old Dec 12, 2006 | 02:15 PM
larryzonka's Avatar
larryzonka
Default Pressure washing?
I have an electric 1200 psi pressure washer.
Vette safe? Yes / No?
(if, yes) Safe for Vert tops?
Old Dec 12, 2006 | 02:19 PM
Oldvetter's Avatar
Oldvetter
I would not use a pressure washer on my C5. Especially not on the engine.
Old Dec 12, 2006 | 02:21 PM
larryzonka's Avatar
larryzonka
Why? It make ruin the clear cloat?
Old Dec 12, 2006 | 02:23 PM
divitasbluepitbulls's Avatar
divitasbluepitbulls
You really don't need a pressure washer if you have a bottle of good ole elbow grease sitting around. Keep the pressure washer for the house or deck not the vette
Old Dec 12, 2006 | 02:26 PM
Oldvetter's Avatar
Oldvetter
1200 psi is way to much, yes it will damage the paint.
Old Dec 12, 2006 | 02:27 PM
larryzonka's Avatar
larryzonka
I got plenty of elbow greese... I was just curious.
Thanks.
Old Dec 12, 2006 | 02:35 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Run it across the top of your foot to test it first. If it gashes you to the bone than it is not safe for the vette...
...Don't really do it...ok?
Peace
Chip
__________________
..................Click for
Old Dec 12, 2006 | 02:39 PM
Deluxe's Avatar
Deluxe
St. Jude Donor '06 thru '16,'22,'24
Gain nothing... lose much.
Old Dec 12, 2006 | 02:43 PM
larryzonka's Avatar
larryzonka
Peace
Chip
Can't press the gas or clutch w/o a foot...
Instead, I will try it on the neighbor's cat. If the fur comes off, then it won't touch the Vette. But it will make a perfect weapon for the cat.
Old Dec 12, 2006 | 02:46 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
I think it will be fine if you have it adjusted to the proper pressure level. I like hand washing mine, but at times, I do take it to the spray and wash when I need to do it quickly.
Old Dec 12, 2006 | 02:55 PM
joshscalf's Avatar
joshscalf
At 1200psi, chances are it'll remove your paint
Old Dec 12, 2006 | 02:57 PM
See if you can find out what the self-serve car washes use in terms of pressure on their equipment. I use a spray and wash quite often on mine and no damage has been done.
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
I wash the outside of mine, when I do, the old fashioned way, a bucket of soapy warm water and a sponge. For the engine compartment I spray it liberally with Simple Green, let sit for 10 minutes or so, then hose off with hot water.
Old Dec 12, 2006 | 03:04 PM
b98's Avatar
b98
bad for the paint.
Old Dec 12, 2006 | 03:05 PM
b98's Avatar
b98
bad for the paint.
Old Dec 12, 2006 | 03:21 PM
larryzonka's Avatar
larryzonka
I suppose if you didn't take the gun and point it point blank to the paint to get the dirt off on full blast, it should be fine.
Perhaps if you were gentle, it would do less harm.
BobbyG: What is this? "...hose off with hot water." My water hose only has cold water...
Old Dec 12, 2006 | 03:22 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
My water is cold too from the water hose. You are lucky if it is coming out warm!
To Pressure washing?
Old Dec 12, 2006 | 04:03 PM
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
I don't agree with all the finger-waggers. Look, just exercise some common sense. 1200 PSI at 3-5 feet away versus 1200 PSI an inch or two from the paint are two different things.
Just keep it out of the engine bay with all the sensitive electronics and you're golden.
I pressure wash my vert all the time, including the top, but just not at close range.
Doesn't hurt anything. Does it look like my 5-year-old paint is washing off? Puh-leez.
Old Dec 12, 2006 | 04:12 PM
larryzonka's Avatar
larryzonka
Awesome info... thanks! Do you use anything else to clean the top? Like RAGTOP or a recommend method for cleaning the top?
Old Dec 12, 2006 | 04:21 PM
JMc's Avatar
JMc
I just use the same car washing soap on the top. Still looks brand new. Seriously.
I may treat it with Ragg Topp in the not-too-distant future, though, just to maintain it.
