Pressure washing?
Old Dec 12, 2006 | 04:21 PM
RedRider98's Avatar
RedRider98
Originally Posted by JMc
I don't agree with all the finger-waggers. Look, just exercise some common sense. 1200 PSI at 3-5 feet away versus 1200 PSI an inch or two from the paint are two different things.
Just keep it out of the engine bay with all the sensitive electronics and you're golden.
I pressure wash my vert all the time, including the top, but just not at close range.
Doesn't hurt anything. Does it look like my 5-year-old paint is washing off? Puh-leez.
Couldn't agree more. Sure, if you put the nozzle one inch from the paint it may do some damage. But, who is dumb enough to do that? Stay at least 3 feet away and you will be fine. I have pressure washed all my vehicles for years and have never had any problems.
Old Dec 12, 2006 | 05:16 PM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
I have seen some stupid accidents used by overzealous pressure washing .Usethe power wisely Luke
Old Dec 12, 2006 | 05:18 PM
02gt350's Avatar
02gt350
what pressure is car washes??
Old Dec 12, 2006 | 05:33 PM
Rans03's Avatar
Rans03
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08
It will not hurt the paint, period!!
Quarter car washes typically use from 1300 to maybe 1400-1500 lbs. Doubt many are at 1500 or over. Stay away from seals and the top(a couple feet is fine) You can get 1500 lbs an inch away from the paint with zero issues
Old Dec 12, 2006 | 05:56 PM
photoguy's Avatar
photoguy
i have taken mine to the self car wash to rinse it off many times.
Just don't hold the nozzle too close and you will be fine.
Old Dec 12, 2006 | 07:29 PM
81c3's Avatar
81c3
I have a 2600 psi Honda pressure washer. I use it on all my cars & all of my past Vettes as well. Nothing cleans tires, wheels & brake calipers like high pressure water. Its totally safe if you just use some common sense. If youre a dumbass and want to hold the wand an inch away from the paint, then youre gonna get what you deserve.
Old Dec 13, 2006 | 02:13 PM
joshscalf's Avatar
joshscalf
I agree that as long as you take care of the paint and are smart about it you shouldn't have any problems. However, on my last car (a Mustang, so that must've been the problem) I was washing it one day at a spray down place. Unknown to me, as time goes on and small particles of grit get in your paint, they pull it up slightly. As it turns out, I learned this because a fist sized area of paint was removed along with the dirt that day. If you clay bar at regular intervals and keep a killer wax job, you should be alright. Just know that there is the potential for paint removal, and you can trust me that it ain't cheap to fix.
Old Dec 13, 2006 | 03:47 PM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
Originally Posted by larryzonka
Can't press the gas or clutch w/o a foot...
Instead, I will try it on the neighbor's cat. If the fur comes off, then it won't touch the Vette. But it will make a perfect weapon for the cat.
This gets better and better.
Old Dec 13, 2006 | 04:13 PM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Originally Posted by Willfulone
Run it across the top of your foot to test it first. If it gashes you to the bone than it is not safe for the vette...
...Don't really do it...ok?
Peace
Chip
Ha -
Old Dec 13, 2006 | 08:12 PM
99 vett babycar's Avatar
99 vett babycar
I must be slow but I don't see what you gain by useing a pressure washer. But I've stripped enough decks to know what the possible losses could be.
Old Dec 13, 2006 | 08:28 PM
tellefan's Avatar
tellefan
I agree about washing decks, I had a cedar deck built this year. It will never see a pressure washer. Both or our C5's have clear bra's on them, a pressure washer will destroy them. Besides I can use the exercise washing them by hand. David
Old Dec 13, 2006 | 08:29 PM
CMYC4GO's Avatar
CMYC4GO
1200 psi is nothing. Most coin operated washes are at least 1400-1500 psi, and sometimes more. I use the Hotsy at work to wash mine on occasion, and it's 2100 psi. No issues. Use some common sense, and you'll be fine.
Old Dec 13, 2006 | 08:33 PM
  #33
99 vett babycar
True, True - but who uses a car wash ?
Old Dec 13, 2006 | 08:56 PM
  #34
Bret01Z06's Avatar
Bret01Z06
Unless you do something stupid, a pressure washer is fine on a vette. It wont hurt clear bras, I'm a professional detailer and use pressure washers all the time. Keep it around 1200PSI and a 45deg nozzle and your fine. I pressure wash my vette all the time, and power wash the engine bay.
Old Dec 13, 2006 | 08:58 PM
  #35
JMc's Avatar
JMc
From: "This is not a psychotic episode, but a cleansing moment of clarity."
I do. Guilty as charged. No apologies, either.
You know, the self-serve kind, not the touchless drive-through -- and that's only because my vert would leak.
My local self-serve car wash is terrific. Sure, I could do it all in my driveway, and sometimes I do, but the self-serve place with hot-pre-soak solution, wheel cleaner, soft, soapy foam brush for gently scrubbing the brake dust off the wheels, high pressure warm wash, rinse and spot-free rinse for $4 and twenty minutes kinda does it for me.
I understand the whole bonding concept by washing your car with a bucket in your driveway while you've got a little soft jazz on the stereo, but this isn't a woman that I'm softly caressing and gently rubbing down with scented oils by candle light.
It's a mass-produced car with hard paint, that can take a good washing with a little common sense and care.
Old Dec 13, 2006 | 09:01 PM
  #36
JMc's Avatar
JMc
The only thing you gain is a sparkling clean car in about half the time. That's it. Just a labor saving device. If you want to do the labor, then right on. I'd rather be driving than rubbing. I'd also be very careful and wary of using high pressure around any unsealed paint chips.
Oh, and your automobile exterior is made of hard surfaces, not oil-saturated wood.
Old Dec 13, 2006 | 09:22 PM
  #37
cruisemon's Avatar
cruisemon
Why? It make ruin the clear cloat?
Naw it wouldn't ruin it. It would strip it. With a tight stream at 1200 psi, I can write my name in cement. As for the vert top, the hole will be the size of the stream. For the engine, it will easily penetrate electrical connectors. That's a seriously bad idea.
Never use a pressure washer at high level. Most drop to a safer level if you pull the nozzle forward. This is the position most use when siphoning liquid soap or cleaner.
Charlie
Charlie
To Pressure washing?
Old Dec 13, 2006 | 09:31 PM
  #38
gillettij's Avatar
gillettij
I've got a 3000 lb/sq if that one doesn't work!
Old Dec 13, 2006 | 09:41 PM
  #39
cruisemon's Avatar
cruisemon
This one doesn't strip paint. It makes stream sized holes in the SMC.
Charlie
Old Dec 13, 2006 | 09:44 PM
  #40
Rans03's Avatar
Rans03
I'd like to add to my earlier reply.
For 10 years I was a Manager of a vehicle pressure washing business. Over 60 full time employees 24/7. We earned well over 3 million/yr. in revenue, only pressure washing vehicles. A service, no products. Pressure washing will not harm your car or strip chit off it unless your paint is damaged already. That is fact.
What # tip, designed for vehicle washing, is cutting into concrete at 1200psi?
