Fuel Filter!!
Old Dec 12, 2006 | 03:47 PM
98blackonblack's Avatar
98blackonblack
Default Fuel Filter!!
How often should you change the fuel filter?
Bought the car with 78000 on it and just hitting all the basics, changing fluids out and plugs and wires....
I found a brand new a/c delco fuel filter off ebay for $28 bucks so I went ahead and got it, but just want to know if it is necessary to change it out or not.
Old Dec 12, 2006 | 03:48 PM
mph1972's Avatar
mph1972
Cruise-In VIII Veteran
St. Jude Donor '07
Where exactly is the filter?
Old Dec 12, 2006 | 03:49 PM
98blackonblack
What do you mean?
Old Dec 12, 2006 | 03:52 PM
divitasbluepitbulls's Avatar
divitasbluepitbulls
I think he is asking where is the location of the fuel filter located on the Chevrolet Corvette C5 1997-2004
mph1972's Avatar
mph1972
St. Jude Donor '07
Originally Posted by 98blackonblack
What do you mean?
The place it is located? On my camaro it was easy to find, not exactly sure where it is on the vette.
Old Dec 12, 2006 | 03:53 PM
98blackonblack
I believe its on the fram rail...
Old Dec 12, 2006 | 03:58 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
I will look it up when I get home and I have the service manuals.
Old Dec 12, 2006 | 04:22 PM
jfrc's Avatar
jfrc
i think it is on drivers side, between seat and rear wheel area
i have new engine, rear end, and trans, all new fluids, etc....
but yet to install a simple fuel filter
Old Dec 12, 2006 | 04:38 PM
02MillenniumVette's Avatar
02MillenniumVette
Here is the tech article on how to change your fuel filter. You should change it once a year if you drive it everyday.
Fuel Filter Replacement
Old Dec 12, 2006 | 04:41 PM
mph1972's Avatar
mph1972
St. Jude Donor '07
Old Dec 12, 2006 | 04:54 PM
ezeddz's Avatar
ezeddz
Default fuel filter
I was told by my local stealership that the fuel filter is inside the gas tank!!! 03 & 04. Who is one to believe? Sounded strange to me.
Old Dec 12, 2006 | 05:01 PM
02MillenniumVette
Im sure someone else will post up to confirm it but I believe the '04 fuel filter is on the inside, Im not sure about the '03. '97-'02 is not though.
Old Dec 12, 2006 | 05:04 PM
On the '00, the fuel filter is located on the frame rail on the driver's side, close to the tranny/differential area. I went to the dealer yesterday for some work on my wife's DD and asked about the cost of a fuel filter from them - $68. (That's for my '00)
Old Dec 12, 2006 | 05:08 PM
Oldvetter's Avatar
Oldvetter
There are three different fuel filters on C5's. The early years with the return fuel line used a cheap ~$16 filter located on the frame rail. Mid-year C5's had a fuel pressure regulator incorperated with the filter, cost around $45. Late year C5's (and C6 by the way) have the fuel filter in the gas tank (around $300 to change).
The good news is that the Shop Manual says you never have to replace the fuel filter unless it is a problem (clogged).
To Fuel Filter!!
