Installing CAGS eliminator
Old Dec 13, 2006 | 04:28 PM
marcous416's Avatar
marcous416
Default Installing CAGS eliminator
Is it necessary to lift the car in order to install the CAGS eliminator or can you do it while its on the ground? Thanks.
Old Dec 13, 2006 | 04:30 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
if you've got long arms you may be able to reach it - if not then you only need to lift it with a floor jack - it does not require a full lift...
Old Dec 13, 2006 | 04:40 PM
StealthZ06's Avatar
StealthZ06
You'll definitely have to jack it up.
Old Dec 13, 2006 | 04:46 PM
FASTFORM's Avatar
FASTFORM
You don't need a lift if you weigh under 40 pounds!
Old Dec 13, 2006 | 05:01 PM
hotwheels57's Avatar
hotwheels57
...or stand less than 4" tall. You'll probably need two hands to disconnect the GM Weatherpack connector and install the CAG device.
Old Dec 13, 2006 | 05:08 PM
vms4evr's Avatar
vms4evr
... or if you have ramps just back it up onto them.
it'll take you longer to jack it up and set the jack stands than it will to install the CAGS.
Old Dec 13, 2006 | 05:10 PM
diyguy's Avatar
diyguy
Suggest a set up ramps - makes things considerable easier, plus you can examine the drive seals while under there too. Then you can lay down on a crawler and slide under with plenty of room.
It sort of takes two hands to get up in there and pull the plugs apart then zip tie everything up and away from heat sources.
Old Dec 13, 2006 | 05:12 PM
rws.1's Avatar
rws.1
i just backed onto my rhino ramps
Old Dec 13, 2006 | 05:18 PM
Ta-taaa's Avatar
Ta-taaa
Do you have a kit? for that or are you DIY?
Old Dec 13, 2006 | 05:28 PM
jfrc's Avatar
jfrc
depends how thin you are
Old Dec 13, 2006 | 07:00 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
This was my 1st (and still my most gratefull) mod. Well worth the $20. Be carefull under there. Safety First.
Old Dec 13, 2006 | 08:40 PM
rwsr50's Avatar
rwsr50
I'm curious, doesn't the front spoiler/air dam hit when you do that? I have Rhino's too, but have only ever driven the front wheels up on them.
Old Dec 13, 2006 | 08:45 PM
Unless you are the thin man, then you need to lift the car. The CAGS connector is located up on the top side of the tranny (driver's side) and I don't see how you could reach it unless you got under the car.
Old Dec 13, 2006 | 08:46 PM
Ta-taaa's Avatar
Ta-taaa
This is how I did mine.. and it's very Cheap.. this link is for the z28 but is the same for the corvette..
http://www.dpatx.com/z28/z28-cags.htm
To Installing CAGS eliminator
