has anyone fixed the climate control display?
Old Dec 14, 2006 | 05:33 PM
MonteHall's Avatar
MonteHall
Cruise-In VII Veteran
St. Donor '03 & '06
Default has anyone fixed the climate control display?
when it's dim... is it just weak solder joints, or an actual component?
Old Dec 14, 2006 | 05:41 PM
d.medic's Avatar
d.medic
St. Jude Donor '10
Default easy fix
This is an easy fix. Look in the tech section, you will find several write ups on it there. My soldering was way less then perfect and it has worked like new for about seven months now. Any questions shoot me a pm
Old Dec 14, 2006 | 05:44 PM
1998 GTR's Avatar
1998 GTR
Very easy! It is just some soldering joints. I did mine 8 months ago and still working great.
Dave
Old Dec 14, 2006 | 07:28 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Here is the definitive fix for all years
http://forums.corvetteforum.com/show....php?t=1316227
Old Dec 14, 2006 | 07:48 PM
Sundevil's Avatar
Sundevil
Did the fix/soldering myself based on those instructions and it worked like a charm. Note though that those resistors aren't poked through the board, they sort of sit on it...held in place by solder. Don't sweat it though. It's sort of a 'remelt' process...doing the job the original production didn't do very well. Good luck! A '2' on a difficulty scale of 1-5. Tiny parts.
Old Dec 14, 2006 | 08:00 PM
VET IT B's Avatar
VET IT B
Did mine, 2000 Vert about 2 weeks ago. Works great. Did it in about an hour and a half. Some of it was spent in cleaning once I got the covers off. Mark
Old Dec 15, 2006 | 08:15 AM
MonteHall's Avatar
MonteHall
St. Donor '03 & '06
so it does work then.
I'm not terribly concerned with component soldering (I'm an Electronics Tech w/ the Coast Guard)
might try to takle this later today.
Old Dec 15, 2006 | 09:49 AM
0EG@EnglandGreen
Supporting Tuner
See post #4
To has anyone fixed the climate control display?
