[Check Engine Light] DTC Code P1415
Old Dec 15, 2006 | 11:50 AM
T-Bone98's Avatar
T-Bone98
Default [Check Engine Light] DTC Code P1415
P1415 - AIR System Bank 1-B is showing up in the DTC codes. Is this something I need to be concerned about or can I just reset the code and not worry about it? Thanks. T-Bone.
Old Dec 15, 2006 | 04:00 PM
Leo3's Avatar
Leo3
I see that you have your dolphins - Ok I do have some information for you -"but" I just got a new computer & cant find how to copy & past yet - the problem is not a big as you think - as soon as I can find out how to copy & paste I will send you the information.
P.S. I had the same problem & had the stealership fix Both sides P1416 is the other side - basicly its is just check valves that get dirty - it get corrroded.
