Trans Fluid Replacement Question
Old Dec 16, 2006 | 12:27 PM
BillW's Avatar
BillW
Default Trans Fluid Replacement Question
I'm not able to remove the fill plug/temp sensor from the trans. I wanted to ask those who've done this work how had can I wrench on that plug? I don't want to break anything. Looks as though there might be some thread sealer on it. Any suggestions appreciated. Thanks. Bill
Old Dec 16, 2006 | 01:00 PM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi Bill -
Yes, the sensor/plug does have some thread sealer or maybe red thread lock compound from the factory.
I just used the appropriate sized open end wrench to remove it.
It is a good sized plug, so it is not delicate.
Just put some muscle into it and it will come out.
best regards -
mqqn
Old Dec 16, 2006 | 01:11 PM
BillW's Avatar
BillW
Thanks. I'm actually using your thread which I saved some time ago to do the job. I'll try putting a little more a** behind it.
To Trans Fluid Replacement Question
