Passenger Seat release bar
Old Dec 18, 2006 | 08:10 PM
ksg32198's Avatar
ksg32198
Default Passenger Seat release bar
I got my car washed today (04 Z06) and they were moving the pass seat back and the handle that you pull up just came off. Has anyone had this happen? I happen to get it back in there working, but now I am parnoid its going to come off in my hand. Car is still under warranty, so I might just let them deal with it. Any suggestions?
Old Dec 19, 2006 | 01:41 AM
PierEagle's Avatar
PierEagle
Not sure if your 04 is same but on 98, the seat back lever is held on by a "c" clip (in the handle). If you align the spline on the shaft with the handle and press the handle on firmly, it should snap on unless the clip is missing or the handle broken. Dealer has them for about $6. If car is still under warr. dealer will most likely replace n/c.
Old Dec 19, 2006 | 01:51 AM
DeeGee's Avatar
DeeGee
Its quite a chore getting the seat covers off to work it. I'd let them fix it under warranty. JMHO.
Old Dec 19, 2006 | 02:25 AM
PierEagle's Avatar
PierEagle
I think he's talking about the plastic lever on the side of the seat base. If so, he shouldn't have to do anything with the seat covers. I replaced the lever and wraparound bezel on mine several months ago, at a total cost of $14.
Old Dec 19, 2006 | 02:32 AM
DeeGee's Avatar
DeeGee
Oops. Misread it thanks. Thought it was the one at the top of the seat.
The lower one comes off "easily" and only fits on with a split pin.
Good instructions on the vette essentials website for that fix.
Step 39a (and 10a to remove)
http://www.vetteessentials.com/instr...er_change.html
Having done it a couple of times, if it feels solid leave it as is.
Old Dec 19, 2006 | 02:50 AM
PierEagle's Avatar
PierEagle
I may be misreading also. We won't know until he comes back on.
Merry Christmas to you in England..Cheers
Old Dec 19, 2006 | 11:04 AM
inospdn's Avatar
inospdn
Manual says to use flat blade screwdriver to push down on C-clip to remove. When reinstalling make sure that C-clip is as high on the plastic shaft as possible (finger pressure only). It should SNAP in place.
Old Dec 20, 2006 | 09:47 AM
ksg32198's Avatar
ksg32198
Sorry if I wasnt clear on the issue. Let me try again. You know on the front of the seat there is a U shaped metal bar that you lift to move the seat back and forth? Thats the bar I was talking about. It seems to be holding again, but I am going to take it to the dealer and let them check it out.
I appreciate all the feedback on it. Sorry I didnt get back on sooner, been so busy with work and trying to finish the Xmas shopping.
Old Dec 20, 2006 | 10:03 AM
Benpup's Avatar
Benpup
Cruise-In VI Veteran
I do belive that is a first. I looked at mine (with a flashlight) but could not see how it could come off. Under warrenty to the stealership. Out of warrenty unbolt seat, turn over, figure out a fix (parts needed etc.)
Good Luck
To Passenger Seat release bar
