[Z06] Napa Rotors
Old Dec 25, 2006 | 10:33 PM
RaleighSS's Avatar
RaleighSS
Originally Posted by lbarnard
Napa are fine. Also check with Rockauto.com. A nice brake upgrade is stainless steel lines. You will see a big difference! ATF Blue!
Whats ATF Blue????
Old Dec 25, 2006 | 10:48 PM
RaleighSS's Avatar
RaleighSS
Originally Posted by RaleighSS
Whats ATF Blue????
hey .. I think i found it... ATE Blue :-)
Old Dec 26, 2006 | 12:37 AM
vms4evr's Avatar
vms4evr
Yep! ATE Blue, Motul RBF600, Castrol SRF. All good race brake fluids. Don't bother doing the flush now with race fluid. It's too soon. About 2-4 weeks before the event would be good.
Don't bother with SS lines and all that stuff now. Go do the HPDE and see what you think. After you do a few if you're hooked then go shopping. All you need now is fresh (or reasonably new) fluids, rotors, pads. Decent set of tires to beat up on the track. Car in good working order. Get your tech done 1-2 weeks before the event. Then go, listen, learn, have lots of fun!
Old Dec 26, 2006 | 07:49 AM
AU N EGL's Avatar
AU N EGL
THSCC Tech days. Best to go to one of the THSCC Tech days
TECH DAYS!!!
Jan 20th K&E 9am - 1pm
Jan 27th HH&W 9am - 2pm (lowered cars referable at this facility)
* K&E Krause & England - Near Angus Barn
HH&W Hubcap Heaven & Wheel - Cary
http://www.thscc.com/timetrial/index.html
Old Dec 26, 2006 | 05:12 PM
lbarnard's Avatar
lbarnard
Good advice.. get to the track and get dialed in with your car, then put a plan together with all the stop goodies. I did my first few track events with all stock parts on my '02 ZO6. Until I started going to more events, and upgrading my car with go fast goodies, just keeping stock parts is fine. However, I did keep the fluids changed in the tranny, clutch, crank case, and brakes on a more than regular basis. Once you get a plan, then get the parts that make sense for your events, and it will save you time and money. Have fun!
Old Dec 26, 2006 | 08:39 PM
RaleighSS's Avatar
RaleighSS
Good advice.. get to the track and get dialed in with your car, then put a plan together with all the stop goodies. Have fun!
Cool.... Will do ... Last time I put pads on the car went to the local autozone and bought the ceramic pads from over the counter... for the street i have had no issues.... also do not get um hot other than the rare blast near the top of 4th.... so i was kinda floored when i saw the price of new OEM pads... boy they are quite expensive... no issues but did not know they were north of 150 for front and just south of 100 rear end...
Old Dec 26, 2006 | 10:22 PM
vms4evr's Avatar
vms4evr
Get a hold of Gene Culley at http://www.gmpartshouse.com/
You should be able to get Z06 front and rear pads for about $200, shipped.
Old Dec 27, 2006 | 07:21 AM
AU N EGL's Avatar
AU N EGL
Unfortunilty the are. Then when, not IF, you decide to do more HPDEs and go to racing brake pads, $350 to $500 a set, which the fronts last 2 maybe 3 weekends. Rears will last 5-6 weekends.
