Passed smog
Old Dec 23, 2006 | 09:19 AM
ROD BROWN's Avatar
ROD BROWN
Default Passed smog
Well I took my car to the Smog Station and I was informed that the cats were burned out.A&A replaced the cats and I passed the smog test with flying colors.Thanks to Andy and his crew,I am now legal.
Old Dec 23, 2006 | 09:32 AM
jrose7004's Avatar
jrose7004
That's great!
Old Dec 23, 2006 | 09:43 AM
Good to hear. Glad we don't have smog checks here.
Old Dec 24, 2006 | 08:12 AM
ROD BROWN's Avatar
ROD BROWN
Default What a Difference
I had no idea that replacing the cats would enhance my performance so much.My mileage went up signifigantly.
Old Dec 24, 2006 | 08:27 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Congrats!
It will if they are shot!
Peace
Chip
__________________
..................Click for
Old Dec 24, 2006 | 01:30 PM
jmzvet's Avatar
jmzvet
I have the same set up as you done by Andy. Do you have all (4) O2 sensors on your LT header exhaust system? I only have 2 (the rears moved the front) and the other 2 deleted. I was told it would not pass with the 2 removed & deleted sensors because it will show up when they plug into the OBDll port?
Old Dec 24, 2006 | 06:28 PM
ROD BROWN's Avatar
ROD BROWN
Default sAM SET UP
[QUOTE=jmzvet;1558236081]I have the same set up as you done by Andy. Do you have all (4) O2 sensors on your LT header exhaust system? I only have 2 (the rears moved the front) and the other 2 deleted. I was told it would not pass with the 2 removed & deleted sensors because it will show up when they plug into the OBDll port?
Thanks[/QUOI have the same setup.I only have the 2 sensors in my exhaust.Andy took the 2 rear sensors and moved them up front.I was really surprised with the increase of performance.It just goes to show,if you don't realize you are losing performance little by little you don't feel it until the problem is corrected.
Old Dec 26, 2006 | 01:53 PM
jmzvet's Avatar
jmzvet
Thanks for the info. I have 3 years left before smog but I should pass if you did .
Old Dec 26, 2006 | 08:42 PM
Dave68's Avatar
Dave68
Jim,
You're due for smog in 2009 and seeing that it is nearly 2007, you've got just a bit over two years left to enjoy those headers - then it's goodbye Sally!
Dave(semilegal)68
Old Dec 27, 2006 | 10:01 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Where was the SMOG done for I am going to get Long Tubes on my Vette and want to pass visual?
Or have you found that most shops don't know the diff?
Thanks,Matt
Old Dec 27, 2006 | 04:41 PM
Red Vamp's Avatar
Red Vamp
I might have to replace mine too. How much did it cost?
Old Dec 27, 2006 | 09:04 PM
eec8059's Avatar
eec8059
Thanks,Matt
O, yes. Please enlighten us.
To Passed smog
