Battery Voltage at Switch On
Old Dec 24, 2006 | 03:20 AM
DeeGee's Avatar
DeeGee
Default Battery Voltage at Switch On
Can some of you check for me
What's your battery voltage read at initial switch on before you start the car?
My battery took a hammering during shipping and it may be terminal (forgive the pun)
Old Dec 24, 2006 | 08:01 AM
eddie44's Avatar
eddie44
St. Jude Donor '03
I just happened to have the dic on voltage when it started last night. I was surprised when it only read 11.2 but slowly worked it's way up to 13.8 as I drove.
Old Dec 24, 2006 | 08:16 AM
FinnZ06's Avatar
FinnZ06
12.5 here..
Old Dec 24, 2006 | 08:36 AM
65GGvert's Avatar
65GGvert
I've been watching mine for some time now, because it seemed low to me. I thought it should read about 12.8 or so, but when it sits a while it reads 11.8 or 11.9. Starts fine everytime and no other issues.
Old Dec 24, 2006 | 08:48 AM
DeeGee's Avatar
DeeGee
Thanks guys. I suspected as much
I'll see how I go. I had it on charge again overnight and I'll leave the battery tender plugged in. I'm only getting 11.3 at start today although that's an improvement over yesterday.
Old Dec 24, 2006 | 12:40 PM
JC in XTC5's Avatar
JC in XTC5
Guys... This has been discussed in excrutiating detail. DO NOT GO BY THE DIC FOR BATTERY VOLTAGE when the car is off. The voltmeter is designed to measure alternator output when the car is running - it will always measure an inaccurately low voltage on the battery when the car is off. Anything from 11.0-11.9 is not abnormal in this mode. With the engine on the voltmeter should show between 13V and 14.5V.
Now measure the battery itself at it's terminals with a DMM if you want to see it's charge. A fully charged battery measures ~12.66 V and a fully discharged battery measures ~11.86 V.
Old Dec 25, 2006 | 01:09 AM
DeeGee's Avatar
DeeGee
Good reminder thanks. Despite watching all that excruciating discussion I'd not taken that onboard.
I'll do just that.
Old Dec 25, 2006 | 04:00 AM
3 Z06ZR1's Avatar
3 Z06ZR1
hmmm, Full charge is 13.2 6 cells 2.2 volts per cell
full discharge is 00.0
Old Dec 26, 2006 | 12:30 PM
JC in XTC5's Avatar
JC in XTC5
Hmmm... Not for car starting purposes.
http://www.uuhome.de/william.darden/carfaq4.htm Table in section 4.4.2.
Old Dec 26, 2006 | 01:33 PM
DeeGee's Avatar
DeeGee
JC
Absolutely correct
10.5 on the DIC but 12.1 on the multi meter
To Battery Voltage at Switch On
