does size matter.... tire question
Old Dec 27, 2006 | 10:46 PM
mcmtac14's Avatar
mcmtac14
Default does size matter.... tire question
Well it's time to repace my very noisy GY run flats with non- run flats. I have seen pics and read posts that indicate the non RFs do not have the same tread width as the same size RF.
What size will work on my 2002 thin spoke wheels, fit well, not rub etc...
The Tirerack site is not showing the tread widths any more!??
Than ks all!
MC M
Old Dec 27, 2006 | 10:52 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Stock wheels are 8.5" wide in front and 9.5" in back - unless you have OEM Z06 wheels which are one inch wider front and rear.
On stock thinspokes - you could go up one size and be okay....i.e: 255-45x17 in front and 285-40x18 in back.
Z06 sizes are 265-45x17 in front and 295-40x18 in back, but that is with a one inch wider wheel.
Old Dec 27, 2006 | 10:53 PM
with the above.
Old Dec 27, 2006 | 10:56 PM
OhioDave's Avatar
OhioDave
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16'17-'18-'19-'20-21
Than ks all!
MC M
The GY runflats do have a 10.3 footprint compared to most non-runflats (275) rear that are close to an inch narrower. Must be the SIDEWALL CONSTRUCTION THAT MAKES THE 1" DIFFERENCE.
Blacksedan87 speaks the truth.
Old Dec 28, 2006 | 02:30 AM
Bill Dearborn's Avatar
Bill Dearborn
GY squares off the EMT tread while the other round theirs on the edges. The rounded eges seem to work better. The GY EMT being wider is a non-issue. The Firestone Run Flats that replaced my EMTs were much better handling and reduced my autocross times when I was running events on stock tires.
Bill
Old Dec 28, 2006 | 08:08 AM
Oldvetter's Avatar
Oldvetter
Here are some tread widths:
Here are the widths from Tire Rack:
The OEM Goodyear runflats are EXTREMELY WIDE for their size. The tread width is even wider than the 295 Z06 tires, here are the specs (tread width)
-Goodyear F1 GS EMT (275) 10.3 inches
-Goodyear Z06 (295) 10.2 inches
-Firestone (275) 8.6 inches
-Goodyear F1 GS D3 (275) 9.4 inches
-Goodyear F1 GS-2 EMT (285, 19 inch diameter) 9.2 inches
Tread widths do make an appearence difference, few of us use the ultimate grip of these tires.
Old Dec 28, 2006 | 08:46 AM
Kebrock's Avatar
Kebrock
St. Jude Donor '11
I've got 295/35/18's on my rears and no problems. They look pretty good too
Old Dec 28, 2006 | 10:45 AM
rws.1's Avatar
rws.1
I agree with Bill Dearborn...
My Auto-X times on Firestone runflats were lower than on the stock GoodYear EMT's....
The Firestones have more grip and better handling as well as lower noise even though that are about 1.5 inches narrower based on TireRacks data
Old Dec 28, 2006 | 10:48 AM
mcmtac14's Avatar
mcmtac14
thank you old vetter! Where did you get these measurements... Tire Rack does not show them any more???
MCM
Old Dec 28, 2006 | 12:15 PM
Oldvetter's Avatar
Oldvetter
MCM
I got them a while ago, some manufacturer's never list their tread width, Michelin is one. Michelin's are often narrower than others, they do get good milege (but not traction).
To does size matter.... tire question
