Header Problem!
Old Dec 28, 2006 | 05:30 PM
bobdt173's Avatar
bobdt173
Cruise-In VII Veteran
Default Header Problem!
I have had them for about a month and they are putting black residue all over the back end of my vette and its loading up really bad. Should I try new O2 sensors, any other suggestions? I know a tune is in order but I would like to wait until May for that.
These pics are taken after my vette has been driven 75 miles on dry roads.
Old Dec 28, 2006 | 05:42 PM
gpracer1's Avatar
gpracer1
At first I thought that was a fleckstone paint job
Maybe the O2 sensors are plugged in wrong....like passenger side to driver side and visa versa.
Old Dec 28, 2006 | 06:23 PM
jeanlucpicard's Avatar
jeanlucpicard
WOW!
I installed my set of SLP long tube headers and ran the car for about 6 months before dyno tuning but never had that problem and I drive an 01 oil burner.
Are you sure you plugged the O2 sensors back in correctly? Crossing them front to back can cause a fuel ratio problem but I just don't see how you could have done that since the wiring harnesses are different lengths. If the sensors were bad you would be backfiring or throwing codes.
Old Dec 28, 2006 | 06:41 PM
DngrZne's Avatar
DngrZne
The headers wouldn't do that. Something has caused the A/F to go waaay too rich.
Old Dec 28, 2006 | 06:46 PM
jeanlucpicard
Could be the MAF?? But you would think a code would appear.
I'll go look in my Helms manuals to see what diagnostic they suggest.
Old Dec 28, 2006 | 07:09 PM
vetpet's Avatar
vetpet
Are you going full throttle during your drive or just cruising around? If you're only in cruise mode you shouldn't see all that carbon residue as the O2's will still try to keep your AFR at around 14.7:1 even if the headers are letting more air pass. If, however, you are putting your foot into it (WOT) then the fuel system goes into open loop mode and your 02's get bypassed and different tables for fueling come into play and they may need to be adjusted because of your headers. I'd also make sure that all of your ignition wires are on good otherwise you could be getting a lot of ignition misfires and partially unburnt fuel is making it way to the back of your car, thus the black speckles. If this is occurring then it will happen at cruise speeds or full throttle. If you're not getting any codes related to the front 02's or the MAF you probably need to get some tuning done.
Old Dec 28, 2006 | 07:12 PM
CorvetteTechInc's Avatar
CorvetteTechInc
After first putting a scanner on it to be sure there are no mechanical issues related to the install (as stated above) you need a good tune!
Old Dec 28, 2006 | 07:35 PM
bobdt173's Avatar
bobdt173
I am not getting on it full throttle, I am usually cruising around. Most of the time it loads up but there is the rare occasion it doesn’t. Most of the time sitting at stop lights the rpms will fluctuate from normal idle to just about to die without touching the throttle. I will check the ignition wires.
Bob
Old Dec 28, 2006 | 07:44 PM
gpracer1's Avatar
gpracer1
Are there any grounds you had to take off for the header install that didnt get grounded back?
Old Dec 28, 2006 | 08:14 PM
bobdt173's Avatar
bobdt173
I believe that everything was grounded correctly.
Bob
Old Dec 28, 2006 | 09:53 PM
oldschoolvette's Avatar
oldschoolvette
After talking to LG Performance I found out that by running a set of rear O2 sensors on the front following header install will help with the too rich issue. Has to do with the higher wattage. The only trick is the rears are a square plug so you will need an adapter to plug them in. I just put a set of LG long tubes on my car, plugged in simulators for the rear O2 sensors and used a set of rear O2 sensors in the front. works fine. Good luck, that might help hold you over until you get a tune.
Old Dec 29, 2006 | 12:25 AM
bobdt173's Avatar
bobdt173
I may have to try this but I cant find any simulators.
Bob
Old Dec 29, 2006 | 06:28 AM
oldschoolvette
L G Performance 1-972-429-1963 If you are running rear O2 sensors make sure they are hooked up correctly. the rears are crossed right to left and left to right. and the fronts hook up right to right and left to left
Old Dec 29, 2006 | 07:35 AM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Get a tune. Looks like it's running way too rich
Old Dec 29, 2006 | 07:46 AM
blazeone's Avatar
blazeone
just think how much of that crap is in your combustion area not too mention what it does to your cats.
Old Dec 29, 2006 | 07:48 AM
Smoke-N-Shot's Avatar
Smoke-N-Shot
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In VI Veteran
Headers are not the problem... You need to look for some other issues that you have...
Old Dec 29, 2006 | 06:33 PM
bobdt173's Avatar
bobdt173
Like what?
Bob
To Header Problem!
Old Dec 29, 2006 | 06:41 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Way
Peace
Chip
__________________
..................Click for
Old Dec 29, 2006 | 07:02 PM
gpracer1's Avatar
gpracer1
If it ran fine before, and after only the header install its now messed up, then it has to be install related. At part throttle the computer will stoich the A/F. Im betting that the O2s are either reversed, not working correctly, or something else related to the install. (loose wire, air leak, etc.)
Old Dec 29, 2006 | 07:18 PM
vetpet's Avatar
vetpet
If you have an air leak anywhere before the front 02 sensors then you will have the PCM trying to add more fuel to compensate for the extra air being seen by the 02's. Any unmetered air (after the MAF sensor) that's getting into the engine through the intake system or air that's getting sucked in around the header flange or a connection (before the front 02 sensors) will cause extra fuel to be added that's not really needed in the combustion process. A bit of fuel specking is not that uncommon when headers are installed before having a tune done but you've got way more than what would be considered 'normal'. If you find you don't have any 'leaks' in the system then you need to get a scanner hooked up to see how well your 02's are switching. A slow switching 02 sensor will not react quick enough to keep the AFR at the correct stoichiometric value (14.67:1). Off hand, I don't think it probably is a WOT problem as headers tend to lean the mixture out and this would be more evident at WOT when the 02 sensors are not referenced for AFR. Keep us in the loop.
