Tire Storage
Old Jan 1, 2007 | 10:46 PM
FRED HAMBLE's Avatar
FRED HAMBLE
Default Tire Storage
I just put on new CCW Chrome 505a and need to store my original C5 wheels and tires. Is there any special way to store them?
FRED
Old Jan 1, 2007 | 10:55 PM
jbauch357's Avatar
jbauch357
This is overkill, but I would:
Make sure they are all aired up and at even pressures then barrel stack them on each other. That way when you pull them out of storage if one is considerably lower than the rest you know there is a slow leak that needs investigation. Also stacking in this fashion, if there is a leak in one of them it won't create a flat-spot in the tread...
Old Jan 2, 2007 | 12:05 AM
GettReal's Avatar
GettReal
Yep..... HANG EM
[IMG][/IMG]
[IMG][/IMG]
Old Jan 2, 2007 | 12:32 AM
MyVetteDream's Avatar
MyVetteDream
From: HOW FAST WAS I GOING OFFICER? Los Angeles Hating GM Dealership Service Dept.'s Since Sept. 2004
St. Jude Donor '04-'05-'06-'07
That's the ticket
Originally Posted by GettReal
Yep..... HANG EM
[IMG][/IMG]
[IMG][/IMG]
Old Jan 2, 2007 | 12:36 AM
Chief777's Avatar
Chief777
St. Jude Donor '15
From tire rack... http://www.tirerack.com/tires/tirete....jsp?techid=37
Depending on how long you plan to store them, be careful, I believe tires have a usefull life around 6 years or so. Hopefully someone smarter than me can validate if this is true or not.
Old Jan 2, 2007 | 01:00 AM
That's how I store mine - and I put a piece of cardboard in between each tire. Mine are stored for about 6 months at a time (switch between summer and winter wheels) and have not had any problems doing it this way.
Old Jan 2, 2007 | 01:17 AM
Bill Dearborn's Avatar
Bill Dearborn
To preserve the tires life a little longer soak them completely (tread, front and rear sides) in Armorall and let it penetrate the tires overnight. Then hand wash/dry and put them in a cool, dry, dark place.
Bill
Old Jan 2, 2007 | 10:00 AM
wolfman04's Avatar
wolfman04
Yep..... HANG EM
[IMG][/IMG]
[IMG][/IMG]
What type of hanger are you using to hang them up?
Old Jan 2, 2007 | 10:18 AM
02HREBlue's Avatar
02HREBlue
Just put up some welded hangers from Griots Garage to hang the wheels and tires up high in the garage. Work terrific and are reasonably priced. Can hang one or two wheels at a time.
Old Jan 2, 2007 | 11:09 AM
Patches's Avatar
Patches
Designed and made my own patterned on some sold by a set formerly sold here by forum member Kerry Yoon. I had them hung, along with my extra top, in my last garage. I have a full basement now with plenty of storage room that is climate controlled so I don't need to "clutter" the garage walls this time. You can do this much more easily and cheaper by buying some of the products available out there but I just enjoy doing these side projects myself. I did buy the top hangers fom Kerry though.
Old Jan 2, 2007 | 01:50 PM
jbauch357's Avatar
jbauch357
Bill
Bill - I know you have a wealth of knowledge, but I have to disagree on this one.
Armorall will deteriorate and dry out the rubber in tires, eventually leading to thousands of spiderweb cracks all over the sidewalls.
Old Jan 2, 2007 | 10:25 PM
FRED HAMBLE
ttt
To Tire Storage
