Quick Amp Install Question
Old Jan 2, 2007 | 10:32 AM
Bullman's Avatar
Bullman
Default Quick Amp Install Question
I have posted in the audio section, but I thought one of you might know the answer.
All I need to know is exactly which wires are the proper ones to wire a PAC adapter in for an external amplifier? It is currenlty wired into the RR speakers and, I think it sounds horrible. Where are they and what colors?
For more detail on what I am doing, please read here:
http://forums.corvetteforum.com/show....php?t=1587239
Thanks,
Bullman
Old Jan 2, 2007 | 11:20 AM
byte_me's Avatar
byte_me
http://www.logjamelectronics.com/pacaoemvet1.html
this is the PAC-OEM I used on my 2001 Z06. It connects directly to the back of the head unit (unplug stock harness from radio, plug in PAC-OEM, plug stock harness into PAC-OEM) then you have to tap into the #8 dark green wire on the stock harness to send a remote signal to the amp. the instructions with the PAC-OEM show this very well. This converts the stock harness to RCA's required to signal the amp.
it was pretty easy with this adapter...I like the plug and play value of it...
Old Jan 2, 2007 | 11:45 AM
Bullman's Avatar
Bullman
I am sure that part will work. I'd like to use the part I already have, a PAC SNI-35 http://www.tune-town.com/installatio...t_reducers.asp, which is hooked in to speaker wires. I have heard that the wires to use are in the door panel, but I do not know which ones and at what point I should tap in. Of course, if the right way to go is to get the PAC OEM, I will.
Thanks,
Bullman
Old Jan 2, 2007 | 12:57 PM
DjCritterus's Avatar
DjCritterus
St. Jude Donor '09
I didn't tap the #8 wire. Instead, I put my remote on a switch so I could turn the amp on/off whenever I want (the SO doesn't like the boom too much).
Old Jan 2, 2007 | 01:41 PM
2K4Vert's Avatar
2K4Vert
Cool idea DJ... where did you mount the switch? Got any pictures?
Thanks...
Old Jan 2, 2007 | 02:44 PM
DjCritterus
St. Jude Donor '09
Thanks...
No pics... baby is in the shop getting custom paint right now. But, I did mount four rocker switches to control various other gadgets where the ash tray once was
For the remote wire/switch combo, I tapped the positive/ground for the cigarette lighter.
To Quick Amp Install Question
