Weird Electrical Problem?
Old Jan 4, 2007 | 07:08 PM
2kbluevette's Avatar
2kbluevette
Default Weird Electrical Problem?
Two months ago started.
Every time it gets dark and the system automatically connect the lights in my 2000 coupe, the headlights fail to rise (light up but still in the low position).
If I actually use the switch, it still fails.
The only way to resolve this is to stop the car, shut down the engine, remove the key, use the switch on then off and then start the car and everything goes normal.
I will apreciatte any suggestion
Old Jan 6, 2007 | 05:23 PM
Qcksilverc5's Avatar
Qcksilverc5
Sorry- not at all sure whats going on there---- good luck with the fix!
