just changed oil need help
Jan 6, 2007 | 06:29 PM
just changed my oil and dont know how to reset the oil life %.i went to that screen and held down the reset button for 30 seconds.what am i doing wrong ,thanks
Jan 6, 2007 | 06:32 PM
Sounds like you did it right to me that is how i do mine.
the screen goes blank then shut the key off and then turn it back on and it should say 100%.
Easy way... Turn key to on. Press gas pedal down three times Fast and start car. It will read 100%
Jan 6, 2007 | 06:44 PM
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Quote:
Originally Posted by
BLAZBYU
Jan 6, 2007 | 07:11 PM
FactoryRaceCar
thanks guys this worked ,you guys guy awesome
Jan 6, 2007 | 07:14 PM
elctroman
your first instinct was right, but the car can't be running. Just turn the key to on and press reset. The gas pedal trick works too, but I have found you can do that accidently.
No problem, glad to be of help.
Take Care!
Jan 6, 2007 | 07:25 PM
It took me a couple of tries because it didn't seem to work the first time..?
Jan 6, 2007 | 08:39 PM
Will it show 100 or 99%? Mine resets and comes up 99%.
Charlie
Jan 6, 2007 | 08:45 PM
cruisemon
Charlie
It shows 100% for about 5 minutes.
If you have Borla Stingers or have the radio up too loud, it starts at 99%...
Jan 6, 2007 | 08:56 PM
GOZ2FST
Charlie
Jan 6, 2007 | 11:51 PM
Glad you got it figured out. I just changed mine on Friday - pushed the reset button until 100% came up.
