Dead battery with tender
Old Jan 6, 2007 | 07:45 PM
doug doo wop's Avatar
doug doo wop
Default Dead battery with tender
Stopped by my friends house, where my '02 is kept in his garage, and found an absolutely dead battery. The tender was on but the first light was flickering (charging light) and the second light(charged) was also on. Any ideas of what the problem is? Thanks
Old Jan 6, 2007 | 07:58 PM
460HP-YLO-JAKT's Avatar
460HP-YLO-JAKT
Were all connections secure?
Old Jan 6, 2007 | 08:04 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
I'll go look at my Tender here in a second, but if one of the lights was flashing, that usually means one of the connections is not hooked up..I;ll have to dig up my instructions and read...but I think that is it..so your battery was probably sitting there all this time with no charge going to it.
Old Jan 6, 2007 | 08:26 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
Your friend probably flips the garage switch "OFF"
Old Jan 6, 2007 | 09:30 PM
99mallett's Avatar
99mallett
From: The line waiting to see Santa Claus stretched all the way back to Terre Haute, and I was at the end, Indiana
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
A red flashing light means no connection or a reversed connection. I have seen one flash red with a battery that had shorted plates (internal short), but that was very rare and it was with a motorcycle battery (which is more common because of their size).
If the battery is hooked up right and is just dead, the red light will glow solid (not flash). When charge is at 75-80% it will flash green, and full charge is solid green.
Old Jan 6, 2007 | 11:14 PM
Rocket02's Avatar
Rocket02
If you hook them up backwards, that will just drain the battery.
If this is the first time going completely dead, you may still be ok, now just put it on a fast charge and let it stay full charged for a few days.
Should be ok after that. Similar to a deep charge.
Old Jan 6, 2007 | 11:44 PM
doug doo wop
I actually checked to make sure the outlet didn't work off of the light switch
Old Jan 7, 2007 | 12:25 PM
JC in XTC5's Avatar
JC in XTC5
Sounds like the battery is dead - likely has a bad cell.
Go to the BT website for more info.
To Dead battery with tender
