NEED HELP <---- ((gas cap))
Old Jan 7, 2007 | 01:41 PM
01vetteC5's Avatar
01vetteC5
Default NEED HELP <---- ((gas cap))
my gas cap button dosnt work how do i fix this -- is it a fuse if soo which one??? or is there something else i can do too pop my gas cap??? need some info soon as possible.... Thanks
Old Jan 7, 2007 | 01:52 PM
Rans03's Avatar
Rans03
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08
Inside the car.....inside the drivers rear quarter panel is a black plastic clip/tab that will pull to the rear of the car and manually release the door for fuel.
Old Jan 7, 2007 | 01:54 PM
JB666's Avatar
JB666
Have you recently had work done where the center console was removed?? Mine wouldn't pop (I was almost out of gas, too), and I found they just didn't snap the connector together properly.
But, as stated above, there's an "emergency release" for times where your switch is bad.
Old Jan 7, 2007 | 02:01 PM
blacksedan87's Avatar
blacksedan87
St. Jude 15 Year Donor
From: "It's 106 miles to Chicago, we've got a full tank of gas, half a pack of cigarettes, it's dark, and
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-‘18-'19
Obviously follow the instruction on pulling the cable to open the cap. But to fix the button - have you checked the fuses?
In the fusebox located under the passenger side footwell - - check the F/TNKDR Minifuse #32 for an open circuit (in other words - is the fuse blown?)
If you know anyone with access to a Service Manual - there is a diagnostic aide listed on page 8-1405 in volume 1 of the manual.
Old Jan 7, 2007 | 02:28 PM
01vetteC5's Avatar
01vetteC5
yea that fixed the problem thanks--- also my power outlet next to the gas release also dosnt work do u know what number fuse that might be--- i dont have my owners manual :o
Old Jan 7, 2007 | 02:34 PM
BlackZ06's Avatar
BlackZ06
Fuse # 1 (20 Amp) is for the console power outlet.
To NEED HELP <---- ((gas cap))
