window seperating from convertible top
Old Jan 8, 2007 | 04:28 PM
fastej's Avatar
fastej
Default window seperating from convertible top
This morning during a rain storm my rear window in my 2000 convertible suddenly came loose allowing rain to enter. It looks as if they are glued in. Local dealership say no repair is possible but must replace the whole top. Seems like a waste since the top is perfect. Any info would be appreciated.Ed.
Old Jan 8, 2007 | 05:07 PM
chaase's Avatar
chaase
St. Jude Donor '12
The dealer is basically correct. I think people have been trying to reseal it in place. Most have failed.
Chris
Old Jan 8, 2007 | 06:26 PM
omarcoolguy's Avatar
omarcoolguy
go to a place that does rag tops.....or leather repairs
Old Jan 8, 2007 | 09:38 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Whatever dealership said "no repair is possible"....is ...the rear glass on my '95 was also heat sealed from the factory and came out right as I was buying it... and I had it fixed 6 years ago and its still doing great...They used some kind of black silicone and it worked great...you just have to find the right place...
Old Jan 9, 2007 | 02:16 PM
white top's Avatar
white top
Letterin Corvette Fever last month from a guy who used 3M double sided tabe the kind you use to attach body side moulding. Sounded like a good idea to me.
Jerry
Old Jan 9, 2007 | 02:35 PM
slpippen's Avatar
slpippen
I have the same problem with my 2000 convertible top. I glued it back together with a glue suggested by a forum member and it stayed together for about three weeks before seperating again. My top is in excellent condition so I can't see having to purchase a new top. There has to be something out there to hold it together. My car has been under cover and in my garage for the last few months but when I get it back out around spring, I'll search again for something else. Maybe the black silicone mentioned.
Old Jan 9, 2007 | 04:40 PM
waupachino's Avatar
waupachino
I believe several Forum member have had luck using JB Weld to glue the rear window back in place.
Old Jan 9, 2007 | 05:39 PM
beefaronie's Avatar
beefaronie
I am sorry, I think you meant to post this in the C6 section.
Old Jan 9, 2007 | 06:17 PM
Frozenfire's Avatar
Frozenfire
I have a 2000 vert also and just recently I noticed the upper left hand corner of the window is beginning to separate. Thanks for the posts and suggestions!
Old Jan 11, 2007 | 07:48 PM
fastej's Avatar
fastej
Default window fixed?!
Took the advice using black RTV silicone and the window seem to be held in real well! Only time will tell if it will last but I took my time and it came out perfect, can't see any silicone. Thanks to everyone for your help!:
Old Jan 11, 2007 | 09:37 PM
BATM4N's Avatar
BATM4N
Someone suggested Gorilla Glue a while back but they never came back to tell if it worked. Whoever makes these has to use some form of glue so once someone figures out what that is.....problem cured.
Old Jan 12, 2007 | 08:58 AM
RPOZ4Z's Avatar
RPOZ4Z
Cruise-In VII Veteran
I used JB weld on mine a few years ago, it's still holding fine!
Old Jan 12, 2007 | 10:11 AM
Cocked and Locked's Avatar
Cocked and Locked
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
Umm, why is that?
Old Jan 12, 2007 | 11:26 AM
SpeedUp's Avatar
SpeedUp
anyone have a pic they could post of this?
Old Jan 12, 2007 | 01:33 PM
BATM4N's Avatar
BATM4N
There was a thread a while back where the whole window came out so don't wait to use JB Weld or whatever you choose because once the whole window comes out it's extremely difficult to line it up perfectly. You'll need two suction cups to hold it and another person to glue it.
Old Feb 20, 2007 | 12:47 PM
pacat's Avatar
pacat
Default What brand of silicone did you use?
Just curious, what brand of silicone did you use? How is it holding up? I have a C4 that the rear window got smashed. The top is like new so I hate to replace the whole top. I found a used rear window from Contemporary Corvette’s in Pennsylvania for $100. I also remember seeing an article somewhere on how to do this repair but now that I need this info I can’t recall where I seen it.
To window seperating from convertible top
