wheel size
Old Jan 9, 2007 | 05:36 PM
04vettecm's Avatar
04vettecm
Default wheel size
Would you stay with the stock size wheels and tires or go bigger?
Old Jan 9, 2007 | 05:42 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
BIGGER is BETTER
Old Jan 9, 2007 | 07:07 PM
molten vett's Avatar
molten vett
I like stock
Old Jan 9, 2007 | 07:09 PM
Oldvetter's Avatar
Oldvetter
I like the security and safety of runflats. I would go to C6 wheel sizes (up one inch) and use the new Goodyear runflats.
Old Jan 9, 2007 | 10:24 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
This is what I did and am fine with this choice,
Old Jan 9, 2007 | 10:41 PM
04vettecm's Avatar
04vettecm
Thanks for the help....rides look nice
Old Jan 9, 2007 | 10:43 PM
Arcane1's Avatar
Arcane1
Supporting Tuner
Cruise-In VIII Veteran
St. Jude Donor '06-'07
I would go with bigger wheels. I am planning to upgrade to a 19*20 CCW package eventually.
Old Jan 9, 2007 | 10:46 PM
unionlandlord's Avatar
unionlandlord
C5 General
From: Boosted in Manhattan & Round Rock TX. President of the Non Club Club of Kansas and Round Rock , Not the flat part.
I someday will go w/some 18/19s or 19/20s
If the price ever comes down .
Paul G
Old Jan 9, 2007 | 10:47 PM
kingsey's Avatar
kingsey
Im going 1 size up.
18/19
zguy's Avatar
zguy
Originally Posted by Glennm27
BIGGER is BETTER
What he said...
Old Jan 9, 2007 | 11:32 PM
TJB-VETTE's Avatar
TJB-VETTE
2023 C8 of the Year Finalist - Modified
2020 C2 of the Year Finalist - Unmodified
the 19/20 setup looks great on lowered vettes. If you plan to stay at stock ride height 18/19 will look fine.
Old Jan 9, 2007 | 11:41 PM
Aggie Doc's Avatar
Aggie Doc
Bigger and Wider and Lower!
18x9.5 19x11
Old Jan 10, 2007 | 12:08 AM
Dave68's Avatar
Dave68
I see these postings quite often......
Disadvantages
of taller tires include a more or less significant loss of performance depending upon the increase in diameter and weight.
With every inch over stock diameter you'll lose 3.5% of torque.
Larger tires and wheels may have a negative influence on stopping power. Know thy weight! You can easily increase each tire/wheel weight by a significant amount. Lighter wheels usually cost more than equivelent-size heavier wheels.
Draw back of heavier tires is a possible decrease of comfort (harsher ride) Lower profile = less cushion.
More unsprung weight means a rougher ride. Your goal should be to keep unsprung weight down as low as possible.
Draw back of wider tires is a loss of steering accuracy, all other things (like sidewall stiffness and speed rating) being equal.
Wider tires have a higher rolling resistance resulting in higher gas consumption.
To gain back some of the lost performance, swapping in numerically higher gears may be a good idea. Still, keep the comments listed above in mind before simply "going larger" when it comes to wheel and tire size.
Old Jan 10, 2007 | 03:15 AM
ICaughtVetteFever's Avatar
ICaughtVetteFever
Good info, bigger is NOT always better.
Old Jan 10, 2007 | 05:20 AM
I've gone the bigger route (19/20) but for my next set I am thinking about going back to the 17/18. May get the wheels in the Z06 widths though.
Old Jan 10, 2007 | 07:45 AM
mike348's Avatar
mike348
I'm staying with 17/18 size. Plenty of tires to pick from at a good price. Do not care for the thin sidewalls on larger rims.
Old Jan 10, 2007 | 07:51 AM
Arcane1's Avatar
Arcane1
Supporting Tuner
Disadvantages
Having now read this I will have to re-think my application. I do like the look of the larger wheels so maybe I will get them and only use them for things like shows and Cruise-In type events. I will just stick with the stock sizes for around town driving.
To wheel size
Old Jan 10, 2007 | 09:52 AM
Dave68's Avatar
Dave68
I've known quite a few people who have "gone big" and gone back". We've all seen little Hondas with 18-inch wheels - rediculous. My 68 C3 had 15-inch wheels! The Tirerack does list wheel weight for some of their wheels; the downside is that they do not know what OEM wheels weigh. Still, there are significant differences (sometimes double) in weight among various wheel types. I'm convinced that with careful shopping, you can go one size larger without adding more weight. "It's gonna cost yah", however!
Old Jan 10, 2007 | 10:11 AM
jaysal555's Avatar
jaysal555
Bigger 18/19 with bigger rubber 275/305
Old Jan 10, 2007 | 11:52 AM
Ephedranator's Avatar
Ephedranator
Default Handling?
On the other side of the looks/bling factor.....how much increase in handling performance can be had. Obviously the wider set of tires (z06) will assist with at the limit handling. Where is the tradeoff for a C5? I always thought less sidewall meant less flex in the tire and more traction....
I would love to have a set of gunmetal C6 rims on my 03 msgm, but any mods, especially more $ tires, and wheels need to pay off in performance for me to justify it.
