Kumho Run Flats
tom...
100 sq ft FATMAT Car Audio Sound Deadener on EBAY,, I bought 2 of them (200sq ft) at $79 per 100 sq ft.. and it really works, so far,, have taken out the rear mats and so far only have done the back end of the car,, will remove the seats next weekend and do the front of the car also.. will let you know..
) I wonder if just lining the bulkhead behind the seats would provide any tire/road noise reduction. Also, would some of this material inside the doors help the sorta flimsy sound when closed.Thanks
I bought Firestone Firehawk runflats to replace the OEM Goodyears and I am very happy. They are quiet, no excessive wear so far after nearly 10,000 miles, and have very nice traction in all weather conditions (well I haven't tried ice).
I complained enough to get the disctrict manager involved and we found out several things:
1) my C5 needed alignment,, I had it done when I put the tires on,,but it needed it again,, probably due to me driving the car everday in Atlanta,,and the potholes are hugh sometimes.
2) Air pressure is very critical. I use to run 28 PSI cold in them and when I went to 32,, the noise went away.. very odd,, rides more harsh, but stlll acceptable.
3) Also said the person that originally balanced them didnt know what he was doing and has been fired from the dealership. They said if I would have come in right away and got them rebalanced then they would not have cupped so badly. Of course my tires are now ruined and they wont replace them..
So the moral of this saga is,,,Get your tires balanced by someone who knows what they are doing and do it regularly (it's usually free where you buy the tires).
SO maybe I cant put all the blame on the Kumhos,, some of it is my fault.... hey as Henry Ford once said" Error is only an opportunity to begin again, more intelligently".
thank s ron
I have been reading/hearing positive things as well--any possibility you got a bad set? Just asking---
