C6 Z06 splash guards
Jan 12, 2007 | 06:53 PM
Question for the guys that have installed the C6 Z06 splash guards. What size whole did you have to drill in the fender for those push pins that hold the splash guard on? Just dont want to make it to big. Thanks
Jan 12, 2007 | 09:30 PM
i don't remember. all i did was hold the drill bit to the pushpin to get the right size.
Jan 12, 2007 | 09:37 PM
I used a 3/8 bit but there are lots of different sizes of push pins out there.
Heres a write up that may help:
http://forums.corvetteforum.com/show...=fender+guards
Jan 12, 2007 | 10:30 PM
I didn't use the pin except on the very bottom. i used the same type 3m tape that they had on it for the Z06. Mine have been on for over a year now.
Danny
Jan 13, 2007 | 07:03 AM
I didn't use the pins. I drilled a 1/8 inch hole and used a screw top and bottom along with the tape.
Jan 27, 2007 | 04:55 PM
Quote:
Originally Posted by
DeeGee
In that write up it posts a part number for "clips". Where do the clips go? or does that part # refer to the push pins that were used?
How many have installed these and has anyone done it w/o drilling holes?
Thanks for any additional info.
Jan 27, 2007 | 05:13 PM
Wonder how may responses this would get in the C6 forum. Just thinkin'.
Jan 27, 2007 | 09:20 PM
UJ, those guys do the same mod to their non-z06's too.
Jan 28, 2007 | 03:41 AM
Z06ufgrad2002
The clips are indeed the push pins thaqt GM supply. It would be hard to fit without drilling holes as the curve of the molding is not the same on the C5 as the C6. The pins pull it into place. That said I think one member used 3M tape.
Jan 28, 2007 | 05:27 AM
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
jdmvette
heck.. they even put Z06 body panels which is how C6s should have came in the first place
