License plate cover - front?
Jan 12, 2007 | 07:56 PM
My wife just got a ticket in Houston for not having the front license plate on. Can anyone tell me about a cover that can be put on over the license plate - now that it has to have one on?
Thank in advance...
Jan 12, 2007 | 08:41 PM
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
Quote:
Originally Posted by
1stGlance
Thank in advance...
There are a couple of options. You can get the factory front plate insert (it comes in black) or you can get it painted body color from various vendors. You can also get a clear cover that is made to fit the C5 from vendors as well.
Jan 12, 2007 | 08:45 PM
You may want to check state laws. If the plate is required on the front it is probably also required to be visible, which would allow only the clear cover.
Jan 12, 2007 | 08:49 PM
1999torchcpe
The factory front plate bracket allows the entire plate to be seen. It's different from the solid cover with the word Corvette embossed into it. I probably shouldn't have referred to it as an "insert".
Jan 12, 2007 | 08:57 PM
St. Jude Donor '06-'07-'08-'09
These folks make a nice plate surround:
http://www.kewlauto.com/ They're available in your body color as well
Jan 12, 2007 | 09:11 PM
C5VetteLS1
That's the one I have also.
Jan 12, 2007 | 11:53 PM
My recommendation would be to get the painted surround and install it. I have it on mine and it makes having to run the front plate more acceptable.
Jan 13, 2007 | 02:08 AM
Senior Member
Cruise-In V Veteran
1stGlance
Thank in advance...
look at my Avatar
Jan 13, 2007 | 02:28 AM
This is the clear cover you were asking about
http://www.ecklers.com/product.asp?p...dept%5Fid=1392
Some members have painted a section inside. One guy made it in the shape of the Chevy logo. Mine's just clear.
You still need to watch out with this option though. Some states don't allow the plate to be covered at all. Not sure about TX.
Jan 13, 2007 | 05:13 AM
St. Jude Donor '08-'09-'10-'11-'12
JDs00PewterCoupe
I agree. You order it in your car color, its a 5 minute install. All the major corvette houses online sell them.
Jan 13, 2007 | 06:02 AM
Jan 13, 2007 | 07:48 AM
JETZ
Hey JETZ, did you paint your cover or have it done? I would be interested in details. Thanks
Jan 13, 2007 | 07:56 AM
Had it done. Just tape off area on the
backside you want exposed, and spray. Simple mod with this cover, keeps the lines of the bumper intact.
Frank
Jan 13, 2007 | 07:59 AM
2015 C5 of the Year Finalist
St. Jude Donor '05-'10
I've got a clear cover on order, from Zip, I was hopin' it would be here by now. And I'm going to do it something like Jetz, but different!
Tell me somethin' Jetz, did you paint from the inside?
TIA
EBZ0602
We must of been peckin' keys at the same time, I see from the backside, I like backsides, well some
Jan 13, 2007 | 03:15 PM
plate cover
JETZ
Frank
Hi Frank, That's the BEST I've seen. How'd you curve the sides so nice ?>George
Jan 13, 2007 | 07:17 PM
Be advised, in TX the word Texas as well as the numbers must be fully visible. Any kind of cover over the plate, such as the clear ones, is illegal.
Jan 13, 2007 | 08:11 PM
You paint from the inside. Its actually pretty easy.
Jan 14, 2007 | 07:48 AM
lt1george
To me, that's the whole point, to match the curves of the outlined area with the curves of cover itself. This way, one compliments the other, and is more uniform, as opposed to using square corners. Sometimes, little details make a big impact.
Frank
Jan 14, 2007 | 08:05 AM
Cruise-In VIII Veteran
JETZ
That looks
Thankfully I am in Florida where they do not issue a front plate.
Jan 14, 2007 | 08:10 AM
Arcane1
That looks
Ya, and I hear it's warm there this time of the year!
