Catch Can
Old Jan 13, 2007 | 11:03 AM
Tim Shaughnessy's Avatar
Tim Shaughnessy
Default Catch Can
Hello All,first time to write in my question is what does a catch can due!!!!Purchase my first Vette (2002 Black rag top) in August 06 in Storage now come on Spring.
Old Jan 13, 2007 | 01:08 PM
TTK98's Avatar
TTK98
It's to keep oil out of the intake. There is a lot of info on the forum about it. Just use the search function at the top of the page. And here's a wave
Old Jan 13, 2007 | 09:03 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Make your own for 1/5th of the price of some seen for sale by vendors. Do a search for the home made catch can.
Old Jan 13, 2007 | 09:05 PM
Arcane1's Avatar
Arcane1
Supporting Tuner
Cruise-In VIII Veteran
But then it wouldn't look as cool.
Old Jan 13, 2007 | 09:06 PM
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Old Jan 13, 2007 | 09:51 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
...And it would not be a two chamber can...
http://www.customcorvetteaccessories...lcatchcan.html
Peace
Chip
__________________
..................Click for
Old Jan 13, 2007 | 10:04 PM
Dave68's Avatar
Dave68
Some interesting info for you....
http://www.conceptualpolymer.com/PCV...oval%20101.pdf
Old Jan 13, 2007 | 10:23 PM
screw991le's Avatar
screw991le
Peace
Chip
Then you get 2 DIY catch cans like me
Old Jan 14, 2007 | 09:08 AM
Tim Shaughnessy
Thanks for the info.
Old Jan 14, 2007 | 09:55 AM
Elite Engineering's Avatar
Elite Engineering
Supporting Vendor
St. jude Donor '14
Tim,
We have a lot of detailed information on our website.
Take a look:
http://www.eliteengineeringusa.com/Catch_Can.html
Elite
Old Jan 14, 2007 | 06:14 PM
stevedun's Avatar
stevedun
Cruise-In 8-9-10-12 Veteran
A question maybe Elite or someone can answer. I just ordered frame rails and the catch can. I may not get the whole picture of how the intake and catch can work, but would the hose going to the intake not be better if it came out of the top of the can, rather than the bottom portion where the oil actually is trapped? Would this not filter and seperate the oil from the intake better? Just curious before I receive it and do the install.
Old Jan 15, 2007 | 02:44 AM
ZeeOSix's Avatar
ZeeOSix
The stainless steel mesh that traps the oil vapors, and condenses the oil which drips back down into the can, is located at the top of the catch can assembly.
If the mess gets saturated during heavy use with liquid oil, it's better to suck from the can on the side fitting because if it was sucking from the top fitting, which is real close the mess, it might suck liquid oil into the intake manifold.
It's better to hook it up like the instructions from Elite show.
http://www.eliteengineeringusa.com/I...uctions_CC.pdf
Old Jan 15, 2007 | 09:44 AM
stevedun's Avatar
stevedun
Will do! Thanks!!
Old Jan 15, 2007 | 10:57 AM
Elite Engineering
Supporting Vendor
St. jude Donor '14
Steve,
Also keep in ming our Catch Can is designed with (2) separate internal chambers.
Jeff
Old Jan 15, 2007 | 01:10 PM
stevedun's Avatar
stevedun
Originally Posted by Elite Engineering
Steve,
Jeff
Gotcha! Will install per instructions.
Old Jan 15, 2007 | 01:18 PM
Blowtorch's Avatar
Blowtorch
You have to admit, they look when done with the braided lines!
To Catch Can
