brightest Reverse lights?
Old Jan 14, 2007 | 10:08 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Default brightest Reverse lights?
I'm planning the blackout reverse light lenses with the crystal reflectors
from C5vetteLs1
I have enough trouble seeing behind me at night as it is
my question is: what is the brightest possible light that will fit in the reverse light housing? I don't have much confidence in the LED bulbs after i tried some in the taillight housings.
There's a small voice in the back of my head suggesting i mount auxillary back up lights inside the rear vents on custom brackets but i'd really like to avoid doing that
Old Jan 14, 2007 | 11:47 AM
jdmvette's Avatar
jdmvette
Night Owl for life
you should just try the stock ones first, they're brighter than LED in this application.
stock on left, LED on right:
Old Jan 14, 2007 | 01:59 PM
spiral04's Avatar
spiral04
How far do you have to back up? I switched the clear housing and LED's and I agree, there isn't enough light. I like the look of the LED's versus the stock bulb though. I thought switching to LED's would be brighter, guess not. I figure the reverse lights are more for the other cars around you unless your back up in long dark areas. If there's another alternative we'd like to know?
Old Jan 14, 2007 | 03:38 PM
bighank's Avatar
bighank
Default back up lamps
I switched the fogs from 38 watt 889 or 893 to 50 watt 885s. What a difference. Anyone know what bulb would be a higher wattage and fit in the back-up light socket without any adverse problems (like melting the plastic lens)? BIGHANK
APPEND: 2357 lamps are about 20% brighter at 3 CP vs the 2057 lamps at 2 CP. At $1 each its worth trying them. Only drawback filiment is rated at 400 hours vs 1200 hours for a 2057 but WHO USES THE BACKUP LIGHTS FOR 400 HOURS?
BIGHANK
Old Jan 20, 2007 | 02:23 PM
bighank's Avatar
bighank
Default bright backup lights
Almost bought 2357 lamps yesterday but saw they were ROUND BASE.
THOUGHT they were like stop/tail 3057 with rectangular base. SILLY ME!!!! Took out socket and found C5 uses a MIXTURE of OLD ROUND base lamps and NEW RECTANGULAR base lamps. Will get the 2357s today at $.99 each and try them out. BIGHANK
Old Jan 21, 2007 | 02:07 PM
bighank's Avatar
bighank
Default backup lights
The 2357s are a lil brighter than the 2057s. Don't think it makes much difference. If you change out the fog lights and use the 885s you will see a BIG difference. Also got some 168 bulbs to put in the side markers VS the 194s in there now. 168 is same filiment configuration but is 3 CP VS 2 CP for the 194s. Too COLD to play with them now. Snowing here today so spring came and went in MD. BIGHANK
Old Jan 21, 2007 | 09:38 PM
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
at a whole $4 expense, i'm going to try the 2357s
Old Jan 21, 2007 | 09:54 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Good choice, the LEDs are not as bright as I have them with my entire black out kit and no issue for me
Old Jan 22, 2007 | 12:54 PM
bighank's Avatar
bighank
Default 2357 cost
Paid $.85 each for the 2357s. Call around they are usually less than a dollar each. BIGHANK
To brightest Reverse lights?
