lowering question
Old Jan 15, 2007 | 10:36 AM
brad6285's Avatar
brad6285
Default lowering question
how much can i lower my c5. can you lower 1 to 2 inches on lowring bolts?
Old Jan 15, 2007 | 11:04 AM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Yes you can
Old Jan 15, 2007 | 12:20 PM
jrose7004's Avatar
jrose7004
I don't think you can get 2 inches without cutting the bushings.
Old Jan 15, 2007 | 12:37 PM
beav626's Avatar
beav626
if lowering on stock bolts do you have to do anythig to the alignment or suspension?
Old Jan 15, 2007 | 01:06 PM
Glennm27's Avatar
Glennm27
If you lower the car using only stock bolt adjustments OR go further, using longer rear bolts and cuttin gfromnt bushings or removing bolts completely you need to have a four wheel alignment.
Either way, when you change the geometry of the suspension, you chance the alignment. Obviously not as severe if only cranking t eOEM bolts but you ARE still changing the geometry and thus changing the alignment.
Old Jan 15, 2007 | 02:56 PM
Glennm27's Avatar
Glennm27
Brad you can lower the car but as mentioned by someone else, using ONLY stock bolt adjustments you will not get 2" of lowering. Only about 1" with the OEM bolts turned to their max.
To go further, you need to buy longer bolts for the rear and cut bushings off of the front bolts or lose the bolts completely. This WILL make the ride a bit harsher, so then I would suggest getting a set of Bilstien Sport shocks or 2004 Z06 shocks and install them too.
They are just about a must have for a Corvette lowered beyond stock bolt adjustments.
Glenn
To lowering question
