Oil Temp. ??
Old Jan 17, 2007 | 06:31 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Default Oil Temp. ??
I notice where people are stating their oil temperatures....Mine always says "low" in the DIC. Is this normal ?
Old Jan 17, 2007 | 09:44 PM
Oldvetter's Avatar
Oldvetter
No, mine always lists the actual oil temperature. I garage it, it gets down to about 52 F.
I also electronically searched the owner's manual for "low oil temperature" and found nothing.
Old Jan 17, 2007 | 09:48 PM
zTrek's Avatar
zTrek
My '02 states a temperature even when cold...
Old Jan 17, 2007 | 10:10 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
I'd guess the sending unit is junk.
The "low" oil temp reading is normal if the oil temp is below about 15*f. I've seen it before. The odd (but also normal) thing is, it will retain that low reading on the DIC even as the car warms up to normal operating temp. If you shut the car off once warmed up, and restart, then you'll get a correct actual reading. That is apparently just a quirk in the software that few people ever see, since most don't drive their Vettes in single digit temps.
I highly doubt you are seeing that cold of temps in La, so I'd be willing to bet it's a sensor issue.
Old Jan 17, 2007 | 11:44 PM
Corvette-Chris
St. Jude Donor '08
Cool...Thanks for the info. Now i have something to do at work tomorrow
To Oil Temp. ??
