[Z06] Katech Value 427 short block $6950
Well guys and gals, I'm happy to announce that the value 427 is ready and awaiting orders. Here are plenty of specs and pictures. If you have any questions let me know. We can also upgrade these with additional parts to make them more complete, or do special orders with variations. LS7 pistons are also available at an additional cost. This price is in place while supplies last. Once we are out of stock of the Cola crankshaft this short block will get a different crankshaft and the price will change.
SPECS:
Part number: KAT-A4684A
displacement: 427ci, 7.0L
bore: 4.125
stroke: 4.000
rod length: 6.100
Compression height: 1.140
Dome volume: -12cc
Compression ratio: 11.0:1 (when using a 65cc chamber), 10.5:1 (when using 70cc chamber)
Crankshaft trigger: 24x
PRICE: $6950 plus shipping
Michigan residents add 6% sales tax
PARTS USED:
Katech sleeved LS2 cylinder case
-double vacuum impregnated
-clearanced for 4.000" stroke
-decked
Cola crankshaft
Callies Compstar H-beam rods
-ARP rod bolts
Katech forged pistons
Mahle rings
1.5mm top and second, 3mm oil
Katech piston pins
-.927 x 2.27 x .155
Clevite / Federal Mogul rod and main bearings
GM Crankshaft sprocket
GM Crankshaft position sensor
GM 24x crankshaft trigger
additional option pricing:
-with Katech forged LS7 pistons, hardcoat anodized
$7230
-with custom pistons and rings for nitrous, or boost
no additional charge, additional lead time of 2-4 weeks
Lovely setup....One bit of marketing advice... not sure if you want to continue calling it a "value" motor. Most people tend to associate that work with cheap parts or sub-standard assembly when in fact your shop and your work is anything but. Yes people can spend tripple that for a C5-R based motor etc, but there's nothing substandard about it.
Reason I say this is because someone brougth it up in another thread and some members made allusions that if you used a $7000 shortblock it'd surely break down the road and that the only way to get a "good" motor was to spend tripple that.
http://forums.corvetteforum.com/show....php?t=1598051
Esp post 27
Esp post 27
Thanks for bringing that thread to my attention. I posted.
We call this our "Value" engine because it is assembled with cost in mind. We DO NOT call this our "budget" engine because budget implies cheap parts. I think Value implies good parts at reasonable cost. Not the cheapest, but still assembled by some of the best technicians in the world.
Call me crazy, but I'd like to know what a product's limits are before buying. Especially if I'm going to drop over $7,000.00 on said product.
So you must have a stock motor Corvette since more power means nothing, right?
Call a company that says "good to 1000hp" and ask them how they know that. Sounds like somebody's opinion to me.
thats awesome
