Oil Capactiy
Old Jan 21, 2007 | 12:55 AM
PewterMetallic98's Avatar
PewterMetallic98
Default Oil Capactiy
How many quarts does a C5 LS1 hold?
Old Jan 21, 2007 | 01:39 AM
unionlandlord's Avatar
unionlandlord
C5 General
From: Boosted in Manhattan & Round Rock TX. President of the Non Club Club of Kansas and Round Rock , Not the flat part.
6.5 If you want it full
Paul G.
Old Jan 21, 2007 | 02:18 AM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
i put in 7 qt
Old Jan 21, 2007 | 02:55 AM
unionlandlord
C5 General
Originally Posted by StephenT
i put in 7 qt
I looked in the book 6.5, but fill it to the full mark in the stick.
Paul G.
Old Jan 21, 2007 | 08:49 AM
Oldvetter's Avatar
Oldvetter
The C5 holds 6.5 quarts of oil.
With that said, there are two full indications on the dipstick. Early years show full at the top of the hash mark (normal full indication).
Later years (not sure about the cutoff) show full at half the hash mark (due to GM changing dipstick tube/stick).
After you drain your oil, and lift the rear higher (to drain out an additional 4 ounces), put in 6.5 quarts of oil. Run engine. Let sit for at least 7 minutes, and observe oil mark, this is your full line. Of course this is on a level surface.
Old Jan 21, 2007 | 08:54 AM
oldschoolvette's Avatar
oldschoolvette
01MY74CvGray's Avatar
01MY74CvGray
St. Jude Donor '05
Old Jan 21, 2007 | 09:23 AM
steve8's Avatar
steve8
6.5 works perfectly for me.
Old Jan 21, 2007 | 09:26 AM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Sometimes it 6.5 and sometimes its 7 qts for me. I just fill it until the dipstick shows full.
Old Jan 21, 2007 | 11:15 AM
ooh yeah's Avatar
ooh yeah
My 01 always takes 7.0-7.2, 6.5 not even close. I've change my oil at least 20 times and its always the same results
Old Jan 21, 2007 | 04:45 PM
photoguy's Avatar
photoguy
7 with new filter.
Old Jan 21, 2007 | 07:40 PM
widewheel's Avatar
widewheel
Six and a half.
Old Jan 21, 2007 | 09:11 PM
2KFRC5's Avatar
2KFRC5
Raise the rear of the Vette only if necessary to level the oil pan.
Quote from shop manual:
Important
In order to completely drain the oil from the oil pan internal baffling, the bottom of the oil pan must be level during the oil drain procedure.
Allow a MINIMUM of 7 MINUTES for the engine oil to fully drain, once the engine oil drain plug and the engine oil filter are removed.
6.5qts for me with PF44
Old Jan 22, 2007 | 03:22 PM
SLWRNU's Avatar
SLWRNU
2026 Restomod of the Year Finalist
If you drain it properly (rear slightly higher than front) and allow enough time for all the oil to drain, it will take 7 quarts. Just did it and dip stick reads right at full.
Old Jan 22, 2007 | 05:52 PM
photoguy's Avatar
photoguy
This isn't brain surgery!
To Oil Capactiy
