Oil Capacity
Jan 21, 2007 | 12:55 AM
Oil Capacity
How many quarts does a C5 LS1 hold?
Jan 21, 2007 | 12:57 AM
6.5 quarts. You're gonna need 13 quarts though.
Jan 21, 2007 | 01:00 AM
Why do you say 13? My old trans am held 5.5. Just didn't know what the C5 would held because of the different pan...
Jan 21, 2007 | 01:02 AM
The book says 6.5 qts.
Some members use as much as 7 qts to reach full on the dipstick. Also some of the guys who track their cars add a little extra.
Don't forget to charge the oil filter before you put it on if you're doing a DIY oil change.
Jan 21, 2007 | 01:05 AM
Mine uses all 7qts with a filter change.
Jan 21, 2007 | 01:09 AM
Supremacy 1 car at a time
Jan 21, 2007 | 01:10 AM
Quote:
Originally Posted by
ElectronBlueC3
I was just jesting with ya because you had two threads about oil.
Jan 21, 2007 | 02:03 AM
In that case make it 19.5
(3 threads)
Jan 21, 2007 | 02:20 AM
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
How many times are you going to ask this question?
Jan 21, 2007 | 02:26 AM
St. Jude Donor '11
jrose7004
Jan 21, 2007 | 05:22 AM
DeeGee
Where do you hook up the positive and negative cables?
Jan 21, 2007 | 06:28 AM
RTFM
Read The Fu**ing Manual
It is listed in the Owner's Manual, along with other
minor information such as what filter (AC-Delco PF46) and oil (Meets GM standard 4718M) to use.
Reason: toned it down
Jan 21, 2007 | 07:22 AM
BlackZ06
RTFM
And don't forget, you can also use a PF44.
Jan 21, 2007 | 07:27 AM
I always put 7L (7.5 qts) in mine
Jan 21, 2007 | 08:35 AM
Mine holds 6.5 quarts, just like the manual calls for. With that amount, the oil level on the dipstick shows full.
Jan 21, 2007 | 08:41 AM
The C5 holds 6.5 quarts of oil.
With that said, there are two full indications on the dipstick. Early (your 1998 is an early year) years show full at the top of the hash mark (normal full indication).
Later years (not sure about the cutoff) show full at half the hash mark (due to GM changing dipstick tube/stick).
After you drain your oil, and lift the rear higher (to drain out an additional 4 ounces), put in 6.5 quarts of oil. Run engine. Let sit for at least 7 minutes, and observe oil mark, this is your full line. Of course this is on a level surface.
Jan 21, 2007 | 08:42 AM
JDs00PewterCoupe
